Newguys
Failed SPI Loopback Test
Sun Sep 22, 2019 3:08 pm
I have wired the MISO and MOSI pins together and ran
./spidev_test -D /dev/spidev0.0
I have alose tried other pins and spidev #'s.
No matter what I try I get
spi mode: 0x0
bits per word: 8
max speed: 500000 Hz (500 KHz)
with no output afterward (not even a 0 bit array)
Is this still possibly a software issue? Or is my BCM chip most likely broken?
RattusRattus
Re: Failed SPI Loopback Test
Sun Sep 22, 2019 7:02 pm
Have you enabled SPI / loaded the device driver?
https://www.raspberrypi.org/documentati ... /README.md
/Rattus
joan
Sun Sep 22, 2019 7:42 pm
Check the version of spidev test you are using. The old version didn't correctly zero the struct passed to the ioctl. This didn't matter on old kernels but causes the error you describe on current kernels.
Newguys
Mon Sep 23, 2019 1:03 pm
/Rattus
Yes I have.
Newguys
Mon Sep 23, 2019 1:06 pm
I am on the most recent kernel (4.19.73-v7+) and I think the latest spidev test. (wget https://raw.githubusercontent.com/torva ... dev_test.c)
Newguys
Mon Sep 23, 2019 1:18 pm
Update
I now am producing bits correctly, but reading 0's. I definitely have the correct pins wired together and am using the correct chipset.
Newguys
Mon Sep 23, 2019 1:21 pm
Update
I now know I am producing bits correctly using a slightly altered test (https://github.com/torvalds/linux/blob/ ... dev_test.c) but reading 0's. I definitely have the correct pins wired together and am using the correct chipset.
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  | ......@....▒..................▒.
RX | 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  | ................................
joan
Mon Sep 23, 2019 3:17 pm
The error seems to be as described. New kernel with old version of spidev test. Perhaps spidev test simply hasn't been updated.
You need to ensure the struct spi_ioc_transfer is zeroed before you use it.
E.g. see http://abyz.me.uk/rpi/pigpio/code/spi-driver-speed.c
Newguys
Mon Sep 23, 2019 4:22 pm
I am confused on what I am supposed to do. I tried running that code and it returned
sps=16453.0: 3 bytes @ 1000000 bps (loops=10000 time=0.6)
joan
Mon Sep 23, 2019 4:36 pm
The code I linked contained an example of how to zero the struct.
Newguys
Mon Sep 23, 2019 5:23 pm
I figured out what you meant. Still receiving 0's. Tried the same SD card on another pi and got the same problem so at least I know it's a software issue. At this point I am wondering if it would take less time to backup what is important and reflash raspbian.
joan
Mon Sep 23, 2019 5:30 pm
Assuming you still have MOSI and MISO linked try the following.
sudo pigpiod
pigs spio 0 50000 0
pigs spix 0 1 2 3 4 5 6 7 8 9 10 11
http://abyz.me.uk/rpi/pigpio/pigs.html#SPIO
http://abyz.me.uk/rpi/pigpio/pigs.html#SPIX
Newguys
Mon Sep 23, 2019 5:44 pm
I changed jumper wires and checked the positioning for probably the 10th time just to be sure.
I still get 0 return:
11 0 0 0 0 0 0 0 0 0 0 0
Also if I try to use python spi from the adafruid-blinka library it gives an error and says to check if it is enabled in the kernel.
As far as I know, it should be enabled if I enabled it in the config, I have dtparam=spi=on in my /boot/config.txt, and spidev0.0 and 0.1 are present in /dev. Correct?
joan
Mon Sep 23, 2019 8:00 pm
I think you are probably not connecting the correct pins.
Can we have a link to a clear photo of your Pi?
Newguys
Mon Sep 23, 2019 8:13 pm
I know they are the correct pins (10th and 11th from the bottom on the left row), they are the same ones I was using before the SPI stopped working on my Pi, I don't have access to it for a picture at the moment.
joan
Mon Sep 23, 2019 9:26 pm
I didn't know it was working and then stopped.
Run wiringPi's pintest or pigpio's gpiotest.
http://abyz.me.uk/rpi/pigpio/examples.h ... l_gpiotest
Newguys
Mon Sep 23, 2019 9:48 pm
Testing...
Skipped non-user gpios: 0 1 28 29 30 31
Tested user gpios: 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
Failed user gpios: None
Newguys
Mon Sep 23, 2019 10:00 pm
I dont know what I did, but now I'm getting
pi@smokercontrol:~ $ pigs spix 0 1 2 3 4 5 6 7 8 9 10 11
11 0 0 1 0 1 2 3 8 1 10 11
.....and after a reboot it's back to the old behavior
Newguys
Tue Sep 24, 2019 12:27 am
I think I might have somehow corrupted the chipset functions in the kernel? I have no other ideas at this point. I tried the SD card on a different ras pi and got the same result, with two other people checking that the correct pins were shorted.
Newguys
Tue Sep 24, 2019 12:36 am
OH MY GOD.
So just for the heck of it, I tried a third jumper wire and it passed the pigpiod test. I managed to grab two different jumper wires that were faulty when testing this.
[strike]I am still getting the following error in python, but my SPI is working correctly.[/strike]
I must have somehow typo'd when I was revising python script without realizing it. There was an extra 1 in my spi initialization, so I was trying to use spi on BCM 111. So a typo in my code, lead me to checking with a bad wire, which led me down a rabbit hole of thinking my SPI was not working.
 Could not open SPI device - check if SPI is enabled in kernel!
value = AnalogIn(mcp, MCP.P0).value #read the adc
  File "/usr/local/lib/python3.7/dist-packages/adafruit_mcp3xxx/analog_in.py", line 61, in value
    return self._mcp.read(self._pin_setting, is_differential=self.is_differential) << 6
  File "/usr/local/lib/python3.7/dist-packages/adafruit_mcp3xxx/mcp3xxx.py", line 93, in read
    out_end=len(self._out_buf), in_start=0, in_end=len(self._in_buf))
  File "/usr/local/lib/python3.7/dist-packages/busio.py", line 169, in write_readinto
    return self._spi.write_readinto(buffer_out, buffer_in, out_start, out_end, in_start, in_end)
  File "/usr/local/lib/python3.7/dist-packages/adafruit_blinka/microcontroller/generic_linux/spi.py", line 93, in write_readinto
    self._spi.open(self._port, 0)
FileNotFoundError: [Errno 2] No such file or directory
