iloveallpi
Serial Console
Thu Sep 05, 2019 11:40 am
Hi all,
I have a device connected to a USB port -> a device the device says its connected to the end point using USB. There USB cable looks like a normal USB Mini A. No serial - USB type cable that I can detect.
The application on the PI reads a number of parameters from the external device but is not reading the correct parameters, I am trying to trouble shoot which data is incorrect or what the application is querying from the device. I know with a serial port you can see the RX and TXD communication between two devices connected via USB.
Is there a way to do this with a USB connection in PI and if so any pointers to where I could start. Thank you
Andyroo
Re: Serial Console
Thu Sep 05, 2019 12:36 pm
Most USB 'sniffers' cost most of an arm and a chunk of leg :(
You could try this https://github.com/usb-tools/USBProxy BUT it is rough and may not work for you (even the author admits it) and the other option (more complex hardware wise) is https://github.com/usb-tools/Facedancer
Without knowing any more about 'the device' its a bit hard to give anything concrete for debugging.
Need Pi spray - these things are breeding in my house...
iloveallpi
Re: Serial Console
Thu Sep 05, 2019 12:50 pm
Thank you - the device is an inverter that I built with a inverter part I bought from China and batteries I connected. They didnt provide any info but *some* api info however the API info doesn't really work wanted to see what I was sending and what it was returning.
scruss
Re: Serial Console
Thu Sep 05, 2019 1:37 pm
Before plugging the device in, enter lsusb in the terminal. Plug it in, and enter lsusb again. Check for differences.
If it's a cheap USB serial device, it's likely to display as a QinHeng Electronics HL-340 USB-Serial adapter or similar. It won't need drivers. Check the end of the output of the dmesg command for any lines like
ch341-uart converter now attached to ttyUSB0
That means your device is available on /dev/ttyUSB0. And yes, HL-340 ≠ ch341, but that's drivers for you
iloveallpi
Re: Serial Console
Thu Sep 05, 2019 2:08 pm
Thank you very much so when I run
dmesg | grep USB*
returns:
[ 0.796537] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.827589] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.835348] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.867194] hub 1-0:1.0: USB hub found
[ 0.981943] usbhid: USB HID core driver
[ 2.397397] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.662067] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 2.678460] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.724587] hub 1-1:1.0: USB hub found
[ 3.091770] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.232056] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.249010] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.365352] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3c:6e:7b
[ 3.481778] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[ 3.637797] usb 1-1.2: New USB device found, idVendor=0665, idProduct=5161, bcdDevice= 0.02
[ 3.668976] usb 1-1.2: New USB device strings: Mfr=3, Product=1, SerialNumber=0
[ 3.720825] hid-generic 0003:0665:5161.0001: hiddev96,hidraw0: USB HID v1.11 Device [STMicroelectronics HID in FS Mode] on usb-3f980000.usb-1.2/input0
[ 3.851803] usb 1-1.4: new low-speed USB device number 5 using dwc_otg
[ 4.019810] usb 1-1.4: New USB device found, idVendor=0c40, idProduct=8000, bcdDevice= 0.01
[ 4.038220] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.182618] hid-generic 0003:0C40:8000.0002: input,hidraw1: USB HID v1.11 Keyboard [ELMCU iPazzPort] on usb-3f980000.usb-1.4/input0
[ 4.356355] hid-generic 0003:0C40:8000.0003: input,hidraw2: USB HID v1.11 Mouse [ELMCU iPazzPort] on usb-3f980000.usb-1.4/input1
If I run the following there are interesting results but they seem to match above:
dmesg | grep usb
[    0.071506] usbcore: registered new interface driver usbfs
[    0.071582] usbcore: registered new interface driver hub
[    0.071696] usbcore: registered new device driver usb
[    0.356435] usbcore: registered new interface driver lan78xx
[    0.356668] usbcore: registered new interface driver smsc95xx
[    0.384899] dwc_otg 3f980000.usb: base=(ptrval)
[    0.788720] dwc_otg 3f980000.usb: DWC OTG Controller
[    0.804360] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[    0.843120] usb usb1: Product: DWC OTG Controller
[    0.850844] usb usb1: Manufacturer: Linux 4.19.66-v7+ dwc_otg_hcd
[    0.858730] usb usb1: SerialNumber: 3f980000.usb
[    0.883583] usbcore: registered new interface driver usb-storage
[    0.974091] usbcore: registered new interface driver usbhid
[    3.668988] usb 1-1.2: Product: HID in FS Mode
[    3.698879] usb 1-1.2: Manufacturer: STMicroelectronics
[    4.055437] usb 1-1.4: Product: iPazzPort
[    4.069279] usb 1-1.4: Manufacturer: ELMCU
[    4.098950] input: ELMCU iPazzPort as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:0C40:8000.0002/input/input0
[    4.222545] input: ELMCU iPazzPort Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0C40:8000.0003/input/input1
[    4.245778] input: ELMCU iPazzPort System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0C40:8000.0003/input/input2
[    4.332131] input: ELMCU iPazzPort Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:0C40:8000.0003/input/input3
[    6.904231] usbcore: registered new interface driver brcmfmac
Then run
lsusb
Bus 001 Device 005: ID 0c40:8000
Bus 001 Device 004: ID 0665:5161 Cypress Semiconductor USB to Serial
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
Now I am trying to marry the two On dmesg it shows almost all of them are allocated to SerialNumber=0 now I am not sure if that is the actual serial connection found on:
lrwxrwxrwx 1 root root 5 Sep  5 12:49 /dev/serial0 -> ttyS0
lrwxrwxrwx 1 root root 7 Sep  5 12:49 /dev/serial1 -> ttyAMA0
My understanding is ttyAMA0 is the bluetooth device. If do a quick:
:~ $ ls -lh /dev/ | grep usb*
drwxr-xr-x  3 root root          60 Jan  1  1970 bus
crw-------  1 root root     10, 203 Sep  5 12:49 cuse
crw-rw-rw-  1 root root     10, 229 Sep  5 12:50 fuse
drwxr-xr-x  2 root root          60 Nov  3  2016 usb
There is nothing around tty<USB_HERE>
However even if I do find the USB link how am I going to see what is being sent and received?
6by9
Re: Serial Console
Thu Sep 05, 2019 2:17 pm
A quick Google on the string "usb 0665:5161" gives a number of hits, including several talking about the device being an inverter.
https://community.cypress.com/thread/30 ... 0&tstart=0
http://allican.be/blog/2017/01/28/rever ... l-usb.html
Linux seems to initially identify it as a Human Interface Device (HID), which is part of the issue. I'll leave you to read the rest of the links and do your own Googling.
iloveallpi
Re: Serial Console
Thu Sep 05, 2019 2:20 pm
Thank you very much for your response. Wasn't sure what to google for i was going down the SMC and dwc_otg route but with no success. Let me go do some reading on those links thank you once again.
scruss
Re: Serial Console
Thu Sep 05, 2019 6:36 pm
Looks like there isn't a kernel driver for this Cypress USB-Serial device, not at least for Raspberry Pi. There's a small change that the serial port is at /dev/ttyACM0 (check for ttyACM in dmesg output) but you may be out of luck with this one.
Though searching for the USB ID string in the forum turned this up: https://www.raspberrypi.org/forums/view ... 61#p499783
- this is for UPS monitoring, but if you can open the device as some kind of serial port, it's a start
