lrhorer
Do GPIO output pins bounce?
Thu Jun 27, 2019 5:35 am
Does anyone know if setting or re-setting a GPIO output pin to its current status will cause the pin to bounce? IOW, if the pin is set high, and one issues a command in Python to set the pin high, does it momentarily drop low, or vice-versa?
PeterO
Re: Do GPIO output pins bounce?
Thu Jun 27, 2019 7:12 am
You are asking about "glitches" rather than "bounces". Bounces are normally taken as being multiple transitions on a state change.
To answer your question , GPIO outputs are glitch free.
PeterO
HermannSW
Sun Jun 30, 2019 10:29 pm
That is good to hear!
I do control 38V/1.5A led drivers powering a 5000lm led via two 24V IRF520 mosfets in series. GPIO13 is connected to SIG pin of both IRF520 modules. When Pi GPIO13 goes from high to low I would expect this:
‾‾‾‾‾‾‾‾|_______
What my 100MSps logic analyzer sometimesshows is this
‾‾‾‾‾‾‾‾|_|‾|______
or even this
‾‾‾‾‾‾‾‾|_|‾|_|‾|______
with width of the short pulses being 10ns.
So is this a problem of having reached maximal resolution of the logic analyzer, or is this real?
[even if it is real, that is no problem for my application, but I want to know]
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
FTrevorGowen
Mon Jul 01, 2019 10:02 pm
‾‾‾‾‾‾‾‾|_______
‾‾‾‾‾‾‾‾|_|‾|______
or even this
Historically I've always used oscilloscopes (never had a "logic analyser" and no longer have access to a 'scope) but maybe what the analyzer is showing is its "interpretation" of "ringing" caused by probe/cable mis-match?
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B+, P3B, B+, A+ and a B2) but Buster on the P4B's. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
