NumiX
SPI: Problem with fast ADC sampling
Sat Apr 27, 2019 2:54 pm
Hey,
im working on a project where i need to sample analouge Signals as fast as possible with a Raspberry Pi. For this case i Use the 3 B+ model an the bcm2835 library with python. The generator puts out a perfect sine-wave at a freq. of a 10kHz.The Sampling looks quite good, but if you look closer you see that the sine-wave in not very accurate. For some reasons the samplnings has not the exact distance to each other. I thougt this is because the OS is doing some stuff in the background so i tried to activte DMA (i set the buffer size >96 bytes as mentioned here :viewtopic.php?t=216532 this should be enough) But it doesnt seem to work. Do you have any suggestions where this is coming from? Thanks in advance :)
This is the Code
#include <stdio.h>
#include <bcm2835.h>
int main(int argc, char const *argv[]) {
    if (!bcm2835_init())
      printf("bcm2835_init failed. Are you running as root??\n");
      return 1;
    if (!bcm2835_spi_begin())
      printf("bcm2835_spi_begin failed. Are you running as root??\n");
      return 1;
    bcm2835_spi_setBitOrder(BCM2835_SPI_BIT_ORDER_MSBFIRST);      // The default
    bcm2835_spi_setDataMode(BCM2835_SPI_MODE1);                   // The default
    bcm2835_spi_setClockDivider(BCM2835_SPI_CLOCK_DIVIDER_16); // The default
    bcm2835_spi_chipSelect(BCM2835_SPI_CS0);                      // The default
    bcm2835_spi_setChipSelectPolarity(BCM2835_SPI_CS0, LOW);      // the default
    char tx0[70] = {0,0};
    char rx[] =  {0,0};
    FILE *fp;
    fp = fopen( "file.txt" , "w" );
    for(int i=0; i<500; i++) {
      bcm2835_spi_transfernb(tx0,rx,2);
      fprintf(fp, "%02x%02x\n",rx[0],rx[1]);
    fclose(fp);
    return 0;
NumiX
Re: SPI: Problem with fast ADC sampling
Mon Apr 29, 2019 6:34 pm
Nobody can help? :|
joan
Mon Apr 29, 2019 7:51 pm
There will be a random delay between each sample. Both the bcm2835_spi_transfernb(tx0,rx,2) and the fprintf(fp, "%02x%02x\n",rx[0],rx[1]) calls may be interrupted.
You are only transferring two bytes so DMA will make no difference. I think it is only used to safely fill the hardware FIFOs and they are probably at least 32 bytes anyhow.
NumiX
Mon Apr 29, 2019 8:21 pm
Hm so you think DMA wont help me to get an uninterruptet samplingrate? Do you have any suggestions how to solve this problem?
joan
Mon Apr 29, 2019 8:54 pm
DMA could help, but not the way you are trying.
See viewtopic.php?t=71089 for one method.
mikronauts
Mon Apr 29, 2019 11:02 pm
Due to Linux, and caching to a lesser degree, you cannot totally get rid of the jitter you are experiencing. The higher the sampling rate, the more apparent the jitter.
Add a deterministic high speed micro controller to do the sampling to a large buffer and have it transfer the data to the pi (some cortex m3's have high speed adc's)
You could try an I2S adc, or usb sound card input, and scale your signal to 0..1v
