Soldering the USB port - does not work
Posted: Sat Apr 06, 2019 2:24 pm
by skyluke
I try to solder a USB cable directly to the USB port. I saw that others de-solder the complete USB connector but there are PPxx that are connected to the USB contacts. This is where I want to solder to. It does not work and don't know why.
This seems to work: https://raspberrypi.stackexchange.com/q ... -usb-ports
Or here: https://raspberrypi.stackexchange.com/q ... usb-port-c
Test Pads: https://sudomod.com/forum/viewtopic.php?t=1491
When I use a normal cable it works fine. 5V is taken from GPIO pin 4 and GND from pin 6 because USB power is not enough and connected directly to the Delock msata board (this is switched using the jumper).
When I solder a cable to the raspi it does not work. I tried different cables ... I tried all can imagine. Please take a look at the picture.
I measured all connections and they are ok. I have no clue. Btw, I changed D+/D- and vice versa - does not change anything.
Did anyone see something like this? Does anyone know why it does not work?
Are there any reasons why it cannot work?
Thank you very much!
Luke
Re: Soldering the USB port - does not work
Posted: Sat Apr 06, 2019 3:15 pm
by bensimmo
Have you tried PP27 for 5VUSB
P.s. no idea, never used that board.
Posted: Sat Apr 06, 2019 3:24 pm
by skyluke
Yes. I tried my cable with USB power, I tried with GPIO power: does not work.
I tried normal cable, with USB 5V and with GPIO power: works fine.
Btw, before cutting the cable I verified that it works. It is the third type of cable that does not work.
What is wrong here?
I have 5V and GND on the Delock board.
I can measure some voltage between D+/D- and GND on the board (whatever I should measure there).
And I can measure that there is an connection between the raspi USB connector and the Delock board.
But the board does nothing. No LED. No boot. Nothing. Like not connected.
Posted: Sat Apr 06, 2019 3:47 pm
by skyluke
I don't believe that it is a problem with the Delock board. I believe that it is a problem with what I did. But what is the problem?
Posted: Sat Apr 06, 2019 4:19 pm
by skyluke
Should I try to solder them directly to the pin for the port and not to the PPs?
Could that make it better?
Posted: Sat Apr 06, 2019 9:12 pm
by drgeoff
Yes.
Posted: Sun Apr 07, 2019 2:28 am
by JohnsUPS
skyluke wrote: Should I try to solder them directly to the pin for the port and not to the PPs?
Yes - I second that.
If soldered directly to where the pins from the USB connector protrude through the board, there is no reason why that shouldn't work.
Prior to soldering to the PP's (or do you mean TP's - test points?), did you ohm out the through-hole USB connections to these pads before soldering anything first?
Posted: Sun Apr 07, 2019 8:46 am
by skyluke
Whatever I do, it doesn't work.
When I solder a cable to one connector it doesn't work but the normal cable connection still works with that connector.
I tried the same with another connector, soldered connection doesn't work, but the normal connection doesn't work, too.
I believe soldering changes impedance that much, so it doesn't work anymore.
Posted: Sun Apr 07, 2019 9:29 am
by Imperf3kt
Are you sure the cable you're soldering isn't damaged in some way?
Posted: Sun Apr 07, 2019 9:49 am
by Burngate
I'd get out my meter, and with a normal cable plugged into the same socket you've soldered to, measure the resistance between the far ends, pin to pin.
You should get close to zero, but I'm betting you don't.
Posted: Sun Apr 07, 2019 9:55 am
by drgeoff
Nonsense.
Posted: Sun Apr 07, 2019 10:36 am
by skyluke
Yes. 4 different cables shouldn't be damaged.
Posted: Sun Apr 07, 2019 10:38 am
by skyluke
Was one of the first things I did: nearly zero.
Posted: Sun Apr 07, 2019 10:44 am
by skyluke
I drilled a hole into the case and used a normal cable.
Posted: Sun Apr 07, 2019 10:44 pm
by Imperf3kt
Where were you supplying 5v from? Your picture only showed three connections and two mystery jumper wires.
I assume this is the board in question?
https://www.delock.com/produkte/1087_mS ... kmale.html
Posted: Mon Apr 08, 2019 12:10 am
by Renate
Just a question out of left field...
Are you sure that your short little cable isn't an OTG cable?
(That would have the ID grounded at the plug going into your red board.)
Posted: Mon Apr 08, 2019 4:05 pm
by bensimmo
pin 4 and pin 6 of gpio.
