Uart Raspberry Pi 3B+ Program
Posted: Sat Dec 15, 2018 9:22 am
by Xedom
I have problem with Uart.
I had write simply program using wiringPi library.
Here is this code in C:
#include <errno.h>
#include <wiringPi.h>
#include <wiringSerial.h>
#include <stdio.h>
#include <termios.h>
#include <unistd.h>
int main(void)
 struct termios options ;
int fd = serialOpen("/dev/ttyS0",9600);
wiringPiSetup ();
 if (wiringPiSetup () == -1)
    fprintf (stdout, "Unable to start wiringPi: %s\n") ;
    return 1 ;
unsigned char sendchar = 154;
serialPutchar(fd,sendchar);
if  (serialDataAvail(fd)){
int recived = serialGetchar(fd);
serialFlush(fd);
serialClose(fd);
printf("%3d \n",recived);
else
printf("None recived");
I enabled Serial ports in raspi-config and add core_freq=250 line to /boot/config.txt.
Also I set serial 0 to 9600 hz in \boot\comandline.txt .
When i run my program i have this:
pi@raspberrypi:~/Desktop/wiringPi/examples/xenitest $ sudo ./test                57
 80
 13
154
154
154
 97
154
154
154
154
154
154
 97
Some of recived values are correct. Can anybody help me with comunication by Uart?
Re: Uart Raspberry Pi 3B+ Program
Posted: Thu Feb 07, 2019 2:59 am
by rzusman
Try flushing the input buffer before you transmit the character.
