Xedom
Uart Raspberry Pi 3B+ Program
Sat Dec 15, 2018 9:22 am
I have problem with Uart.
I had write simply program using wiringPi library.
Here is this code in C:
#include <errno.h>
#include <wiringPi.h>
#include <wiringSerial.h>
#include <stdio.h>
#include <termios.h>
#include <unistd.h>
int main(void)
 struct termios options ;
int fd = serialOpen("/dev/ttyS0",9600);
wiringPiSetup ();
 if (wiringPiSetup () == -1)
    fprintf (stdout, "Unable to start wiringPi: %s\n") ;
    return 1 ;
unsigned char sendchar = 154;
serialPutchar(fd,sendchar);
if  (serialDataAvail(fd)){
int recived = serialGetchar(fd);
serialFlush(fd);
serialClose(fd);
printf("%3d \n",recived);
else
printf("None recived");
I enabled Serial ports in raspi-config and add core_freq=250 line to /boot/config.txt.
Also I set serial 0 to 9600 hz in \boot\comandline.txt .
When i run my program i have this:
pi@raspberrypi:~/Desktop/wiringPi/examples/xenitest $ sudo ./test                57
 80
 13
154
154
154
 97
154
154
154
154
154
154
 97
Some of recived values are correct. Can anybody help me with comunication by Uart?
rzusman
Re: Uart Raspberry Pi 3B+ Program
Thu Feb 07, 2019 2:59 am
Try flushing the input buffer before you transmit the character.
