Tom Lewis
Baisc GPIO basic switch
Wed Nov 14, 2012 3:07 pm
Hello all, im a noob when it comes to electronics, I have myself a basic starter kit with breadboard and so far have managed to turn on and off some LED's, my next test is inputing via switches, I bought a bunch to play with, one is a "missile launch switch" So either on or off, How would I wire this to the pi's GPIO? Also what kind of signal would this send back to the pi? Would it send an "on" signal once? The idea would be to pickup this signal in PHP and do with whatever...
Dweeber
Re: Baisc GPIO basic switch
Wed Nov 14, 2012 3:21 pm
One of my first projects included using a switch.
http://rpi.tnet.com/project/hardware/project001
The page includes breadboard layout, and photos of the actual construction. I didn't use PHP for the script (Which when sensing the button is pressed, causes the system to do a shutdown), but I could have called the same code from a PHP script.
There are other examples on the Raspberry Pi Wiki as well.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
Grumpy Mike
Thu Nov 15, 2012 1:29 pm
One wire to the GPIO pin and the other to the ground pin.
When your program initialises this GPIO pin as an input, you should also specify you want the pull up resistor to be enabled. However if you use GPIO 0 & 1 on the old issue 1 boards or GPIO 2 & 3 on the new issue 2 baords then there is already a hardware pull up resistor fitted so there is no need to enable the internal one. It does no harm if you do however.
A logic level signal. When reading the GPIO pin you will see a logic zero when the button is pushed and a logic one when it is not. These are also called true / false levels in Boolean logic.
As long as the button is held down it will return a logic zero, it will only read back as a logic one when you release the button.
Arjan
Thu Nov 15, 2012 6:46 pm
The picture below shows a commonly used circuit for reading the state of a push-button.
Arjan
http://www.raspberrypi-dmx.org/
Open Source DMX/RDM/MIDI/OSC/Art-Net/sACN solutions
