ndcube
Controlling SPI Clock
Fri Nov 30, 2018 12:34 am
Is there a way with wiringPi or otherwise to control the SPI clock after using wiringPISpiSetup?
For example I have a requirement to hold the clock low for a number of cycles in order to reset the interface on a chip.
joan
Re: Controlling SPI Clock
Fri Nov 30, 2018 1:57 pm
The SPI peripheral hardware on the Pi controls the clock timing. I suppose you could take the SCLK GPIO out of SPI mode temporarily, do what you need, and then return the GPIO to SPI mode.
ndcube
Tue Dec 04, 2018 8:02 pm
Thank you. Are there any API calls that can do that? After setting the pin in GPIO mode the only way I have found to get it back to SPI is to unload and load the spi kernel module.
ndcube
joan
Tue Dec 04, 2018 11:43 pm
I am fairly sure that wiringPi has calls to set GPIO mode.
