-iak-
Can't handle backlight on Chalkboard touchscreen
Fri Nov 23, 2018 4:09 pm
Hi everybody, I just installed Raspbian on a Raspberry Pi 3 B+, and connected it to the 10" Chalkboard multitouch LCD [https://www.chalk-elec.com/?page_id=128 ... ry=3094861].
In order to properly manage backlight I updated the firmware to the last version available (the one with the multitouch feature) and tried to install the LCD control GUI, as suggested here → https://www.chalk-elec.com/?p=2144.
The Chalckboard page (2nd link) says that "The simplest way to communicate with HID devices is to to use cross-platform library HIDAPI from Signal11. "
This is the link to Signal11's github↓
https://github.com/signal11/hidapi
I followed the instructions to install it:
./bootstrap
./configure
make
make install
but nothing happens.
Then I noticed that the folders available here → https://drive.google.com/drive/folders/ ... jQ1QmVoR0U look similar to the one from github and I wonder if I had to merge them in some way.
Now my backlight is sat to minimum (default setting) and I still can't do anything to control it.
Did I miss something? If so, what's the proper way to install the LCD backlight control?
Thanks in advance,
Andrea.
aBUGSworstnightmare
Re: Can't handle backlight on Chalkboard touchscreen
Sat Nov 24, 2018 6:19 am
Why don't you ask the supplier/manufacturer for support?
Only persons which have this particular product might be able to help. But don't know if some of them are here ...
-iak-
Mon Dec 03, 2018 4:22 pm
Sorry for my delay in answering. I wrote to Chalkboard and they didn't say anything useful except that I should use HID commands.
Then I wonder what is the tarball provided for.
I can't understand, so there's nothing to install?
If so, is there anyone with some HID commands experience to address me in the right way to understand them?
