PhilE
New "gpio" config.txt command announcement
Thu Mar 22, 2018 1:11 pm
This topic is for discussion of and questions about the announcement of the new "gpio" config.txt command, which can be found here.
calleblyh
Re: New "gpio" config.txt command announcement
Thu Mar 22, 2018 5:14 pm
gpio readall doesnot behave as it used to when running PI3B+ under 2018-3-13. Is there a problem ? I have posted this question earlier in Beginners before I found this announcement.
PhilE
Thu Mar 22, 2018 5:26 pm
The error message is fairly clear:
Oops - unable to determine board type... model: 13
gpio is part of the WiringPi package maintained by Gordon Henderson (gordon@drogon.net). He needs to add the type for 3B+ (13) to the list - I'll ping him an email.
But that is nothing to do with this announcement, which is about a new config.txt setting.
ShiftPlusOne
Thu Mar 22, 2018 5:30 pm
He has updated it, we just don't have it in apt yet.
PhilE
Unsurprisingly, Gordon has already updated WiringPi - it's just the the Raspbian packages haven't picked up the latest build (2.46). You can download directly from drogon.net like this:
cd /tmp
wget https://unicorn.drogon.net/wiringpi-2.46-1.deb
sudo dpkg -i wiringpi-2.46-1.deb
I'll redirect my ping to ShiftPlusOne to pull in the update.
Thu Mar 22, 2018 5:44 pm
How do we avoid your gpio command conflicting with Gordon's (long time) existing gpio command? It appears you've missed the clashing of names or is it a copy of his code with new function?
This is a doctor free zone.
hippy
Thu Mar 22, 2018 5:45 pm
From the announcement; "the syntax is based on the raspi-gpio utility"
Can someone provide a link to where that is described for those of us not familiar with raspi-gpio. I Googled but what I found seemed to have a very different syntax to the examples shown in the announcement.
I don't know how relevant what it is based on is so it might be best not to even mention that, just describe the syntax used.
PhilE
@DougieLawson Read the post (or even just the bit you quoted) - it is a config.txt setting.
PhilE
Thu Mar 22, 2018 5:47 pm
pi@raspberrypi:~ $ raspi-gpio help
WARNING! raspi-gpio set writes directly to the GPIO control registers
ignoring whatever else may be using them (such as Linux drivers) -
it is designed as a debug tool, only use it if you know what you
are doing and at your own risk!
The raspi-gpio tool is designed to help hack / debug BCM283x GPIO.
Running raspi-gpio with the help argument prints this help.
raspi-gpio can get and print the state of a GPIO (or all GPIOs)
and can be used to set the function, pulls and value of a GPIO.
raspi-gpio must be run as root.
Use:
  raspi-gpio get [GPIO]
OR
  raspi-gpio set <GPIO> [options]
OR
  raspi-gpio funcs [GPIO]
OR
  raspi-gpio raw
GPIO is a comma-separated list of pin numbers or ranges (without spaces),
e.g. 4 or 18-21 or 7,9-11
Note that omitting [GPIO] from raspi-gpio get prints all GPIOs.
raspi-gpio funcs will dump all the possible GPIO alt funcions in CSV format
or if [GPIO] is specified the alternate funcs just for that specific GPIO.
Valid [options] for raspi-gpio set are:
  ip      set GPIO as input
  op      set GPIO as output
  a0-a5   set GPIO to alternate function alt0-alt5
  pu      set GPIO in-pad pull up
  pd      set GPIO pin-pad pull down
  pn      set GPIO pull none (no pull)
  dh      set GPIO to drive to high (1) level (only valid if set to be an output)
  dl      set GPIO to drive low (0) level (only valid if set to be an output)
Examples:
  raspi-gpio get              Prints state of all GPIOs one per line
  raspi-gpio get 20           Prints state of GPIO20
  raspi-gpio get 20,21        Prints state of GPIO20 and GPIO21
  raspi-gpio set 20 a5        Set GPIO20 to ALT5 function (GPCLK0)
  raspi-gpio set 20 pu        Enable GPIO20 ~50k in-pad pull up
  raspi-gpio set 20 pd        Enable GPIO20 ~50k in-pad pull down
  raspi-gpio set 20 op        Set GPIO20 to be an output
  raspi-gpio set 20 dl        Set GPIO20 to output low/zero (must already be set as an output)
  raspi-gpio set 20 ip pd     Set GPIO20 to input with pull down
  raspi-gpio set 35 a0 pu     Set GPIO35 to ALT0 function (SPI_CE1_N) with pull up
  raspi-gpio set 20 op pn dh  Set GPIO20 to ouput with no pull and driving high
Thu Mar 22, 2018 5:50 pm
So it's not a "gpio" command, it's new function in your "raspi-gpio" command. Which really isn't clear from what you've written (unless you're applying Humpty Dumpty's rules).
PhilE
Thu Mar 22, 2018 5:54 pm
Really?
The latest firmware - build date 21/03/18 or later - includes a new config.txt command
The "gpio" command respects the "[...]" section headers in config.txt,
Thu Mar 22, 2018 5:58 pm
It's NOT a "command" it's a "keyword with operands" in config.txt. In my vocabulary a "command" is usually a program in /bin, /sbin, /usr/bin, /usr/sbin, /usr/local/bin or /usr/local/sbin that runs from a command line.
PhilE
Thu Mar 22, 2018 6:02 pm
It is interpreted and acted upon as it is encounted, as opposed to simply setting a flag for use layer, so I think the word command is reasonable and reflects the imperative nature. I considered the word directive, but that's a bit highbrow.
This is turning into a bikeshed discussion.
PiGraham
Thu Mar 22, 2018 6:07 pm
It looks like a new gpio command modelled on an existing raspi-gpio shell command, but the new one applies only in config.txt.
So this sets pullup on GPIO20 from command prompt or script file:
And this will do the same thing from config.txt at boot:
 gpio set 20 pu
I think that's what it means.
hippy
Thu Mar 22, 2018 6:08 pm
From the announcement ...
"np - No pull"
From raspi-gpio help ...
"pn set GPIO pull none (no pull)"
hippy
Thu Mar 22, 2018 6:10 pm
 gpio set 20 pu
My reading of the announcment is the last should be as follows when in config.txt ...
gpio=20=pu
I think that perhaps the reference to raspi-gpio has got everyone confused.
PiGraham
Thu Mar 22, 2018 7:42 pm
 gpio set 20 pu
gpio=20=pu
You seem to be correct on both counts.
Fri Mar 23, 2018 10:57 am
Does anyone actually have anything useful to say on this cool new feature?
hippy
Fri Mar 23, 2018 2:29 pm
There's that discrepancy I noted in my earlier post -
viewtopic.php?f=44&t=208747#p1290616
nixy82
Sat Mar 24, 2018 8:48 am
This is great!
We’re a step closer to not needing custom device tree blobs in our compute module application now :D
Any chance you can do something for camera (dual) configuration in a similar style?
PhilE
Sat Mar 24, 2018 11:45 am
By that you mean add the ability to assign a pin number to one of the named roles - CAMERA_0_SDA_PIN etc.? The plumbing internally is likely to be the hardest part, but I can take a look.
CCMike
Thu Mar 29, 2018 5:32 pm
Will this, or has it already, be back-ported into Jessie? Thanks!
ShiftPlusOne
Thu Mar 29, 2018 5:36 pm
Jessie is unsupported, but you might have luck with using rpi-update to get the required firmware update.
Gavinmc42
Mon Apr 02, 2018 6:03 am
What reads the config.txt and sets the GPIO pins? bootcode.bin, start.elf or is it passed to the kernel?
Basically is this config.txt option available to those who don't use Linux.
I'm dancing on Rainbows.
PhilE
Mon Apr 02, 2018 6:43 am
It's handled by start.elf and its variants, so the mechanism should be usable with any operating system that doesn't overwrite the pin states at boot time.
