Pencoys
RPi0 camera connector
Fri Jun 17, 2016 2:52 pm
Ok, the Zero camera connector is so flimsey that I, as an experienced engineer, managed to break it.
What is the connectors RS or Farnell order code ? . Thinking of buying a few to replace breakages further down the line.
thanks
MarkHaysHarris777
Re: RPi0 camera connector
Sat Jun 18, 2016 3:18 pm
... seems to be a common problem; not to feel bad.
marcus
:ugeek:
Pencoys
Sat Jun 18, 2016 5:42 pm
MarkHaysHarris777 wrote:.. seems to be a common problem; not to feel bad.
your beard is better than mine. but I still need a part number :-)
6by9
Sat Jun 18, 2016 6:58 pm
As stated in the original release, it's the same as the Compute Module, and the full BOM of the CMIO is part of the docs at https://www.raspberrypi.org/documentati ... gnfiles.md
From the BOM
Item	Quantity			Reference	Part	Manufacturer	Manuf. Part No	Description
15	4	J9,J10,J11,J12	54548-2271			Molex	54548-2271	0.5MM FFC 22W RA BC
