hatamiarash7
I2C Address , 7-segment
Mon Apr 11, 2016 7:37 am
hi
i have a 4-digit seven segment module and i have something like this for
i2cdetect -y 1
. how can i write a simple program ??? which one is my true address ? :cry: :cry: :cry: :cry: :?: :?: :?: :?:
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- 24 25 26 27 -- -- -- -- -- -- -- --
30: -- -- -- -- 34 35 36 37 -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Richard-TX
Re: I2C Address , 7-segment
Sun Apr 17, 2016 4:39 am
Without at least a description of how you are interfacing the 7 segment display to the I2C bus, of at least the device's number, no one can help you.
Personally I would use multiple BCD to 7 segment drivers and a MCP23017 to drive the display. It makes life a lot easier. Write a 8 and "8" is displayed. Depending on the driver chip, Hex (A-F/a-f) can also be displayed.
Additionally a single MCP23017 could handle the interfacing needs for all four digits of your 7 segment display.
Now if your display has a native I2C interface, then you don't need the MCP23017 or the BSD decoder chips. You are going to have to decipher the display's data sheet. I suspect that each digit would have it's own address on the I2C bus. Why you have 8 addresses showing is a mystery. Check the display's wiring. Leave no lines open.
Richard
Doing Unix since 1985.
The 9-25-2013 image of Wheezy can be found at:
http://downloads.raspberrypi.org/raspbian/images/raspbian-2013-09-27/2013-09-25-wheezy-raspbian.zip
brekee12
Sun Apr 17, 2016 8:10 am
Do not forget about the 0 bit which is RW. You can see addresses which should be used in your program. If you like you can convert the addresses as you want taking consideration this RW bit.
Brekee12
on a Raspberry B+ with whezzy, two Zero with Jessie Light
Sun Apr 17, 2016 2:12 pm
Richard-TX wrote: Personally I would use multiple BCD to 7 segment drivers and a MCP23017 to drive the display. It makes life a lot easier. Write a 8 and "8" is displayed. Depending on the driver chip, Hex (A-F/a-f) can also be displayed.
Personally I'd use a MAX7219 which is available from eBay for less than a fiver
http://www.ebay.co.uk/itm/MAX7219-LED-M ... 1894486431
and has a ready to run library https://github.com/rm-hull/max7219
It's SPI, but works really well on my RPiZ.
This is a doctor free zone.
