Cole1717
Lighting up 5 LEDs with I2C or SPI
Thu Jun 18, 2015 11:53 pm
I would like to be able to have say 5 LEDs that I can toggle each on individually. For example, I would like to tell it to turn on the first three or every other one on, but keep the other ones off. I don't want it to be limited by the number of output pins I have on my pi 2, so I am guessing the best way is to do it with I2C or SPI. I just don't really know how to go about doing it. I am guessing it involves a decoder and several flip flops or maybe I am completely wrong and there is an easier way. Any suggestions?
Thanks for your help, I'm new to pi.
mikronauts
Re: Lighting up 5 LEDs with I2C or SPI
Fri Jun 19, 2015 12:18 am
Use MCP23017 I2C I/O expanders, you can have eight of them, with 16 I/O's each, on an I2C bus.
I use them a fair bit, so I even designed a board around them that holds two of them :)
http://www.mikronauts.com/raspberry-pi/pi-rtc-dio/
Here is an article on how one I use to read a 4x4 keypad:
http://www.mikronauts.com/raspberry-pi/ ... nd-python/
There are a ton of other examples, google "raspberry pi mcp23017"
Cole1717 wrote:I would like to be able to have say 5 LEDs that I can toggle each on individually. For example, I would like to tell it to turn on the first three or every other one on, but keep the other ones off. I don't want it to be limited by the number of output pins I have on my pi 2, so I am guessing the best way is to do it with I2C or SPI. I just don't really know how to go about doing it. I am guessing it involves a decoder and several flip flops or maybe I am completely wrong and there is an easier way. Any suggestions?
joan
Fri Jun 19, 2015 7:57 am
Ditto the MCP23017.
Here is one driving some LEDs.
FTrevorGowen
Fri Jun 19, 2015 2:00 pm
There is also the MCP23008 (it's 8-bit cousin)** and, the somewhat simpler to program, PCF8574 (also 8-bit)****. Both are I2C devices. FWIW, an example of their use with various LED's can be found here:
http://www.cpmspectrepi.webspace.virgin ... oFull.html
Trev.
** SPI versions of both MCP devices also exist.
**** Often used for (4-bit) I2C interfaces to LCD displays (16x2, 20X4 etc.)
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Cole1717
Fri Jun 19, 2015 4:10 pm
Thank you so much! I love these forums. I'll order some and try them out.
FTrevorGowen
Fri Jun 19, 2015 4:20 pm
Cole1717 wrote:Thank you so much! I love these forums. I'll order some and try them out.
Have fun & let us know how you get on.
Trev.
