murratw
Mirror GPIO pins
Tue May 12, 2015 11:19 pm
Is there a way to mirror the GPIO pin output? I need to put a hat on backwards . I believe this would require mirroring the GPIO pins.
electronicsguy
Re: Mirror GPIO pins
Wed May 13, 2015 12:05 am
murratw wrote:Is there a way to mirror the GPIO pin output? I need to put a hat on backwards . I believe this would require mirroring the GPIO pins.
not with software. you could design a custom pcb with headers on both sides and tracks connecting them in a twisted fashion.
blog: https://electronicsguy.wordpress.com
github: https://github.com/electronicsguy
ame
Wed May 13, 2015 12:09 am
Desolder the pins and re-solder them on the other side of the board.
ame
Wed May 13, 2015 12:11 am
Or use a ribbon cable and plug it in backwards.
