how read data from DS3231
Posted: Sat Apr 25, 2015 10:35 am
by rapidograf
Dear Sirs
Colud you are please give good sampleas how read data from the RTC DS3231,
i check the connection by the sudo i2cdetect –y 1 device is in I2C map.
But how read tada i can not understand, when i reda followings topics i totally have to confusion and missunderstanding ....
where get driver
insatll
read and etc :roll: :shock:
I already red following topics.
viewtopic.php?f=44&t=99141&p=690492&hil ... 31#p690492
viewtopic.php?f=44&t=98318
viewtopic.php?f=46&t=104328&p=720666&hi ... 31#p720666
:?: :arrow: :idea:
Re: how read data from DS3231
Posted: Sat Apr 25, 2015 10:46 am
by MarkHaysHarris777
Greetings, I understand. Reading the i2c bus is very confusing for everyone; do not feel like you're alone on that one!
How you read i2c bus depends on the interface you are using (do you have an i2c block?) and whether you are using a library (like mraa, or other) or whether you are writing your own library...
Typically you need to know what address your slave device is on... your i2cdetect command will tell you this... if the device is working it will show up as a device with a specific hex address, like 0x48 for instance.
To read from an i2c address you need to tell the bus what address you are going to read|write. Then, you need perhaps to write a configuration data stream to the configuration register (not always required). Then, you need to write to the register you are going to read from ( some commands in the mraa library do that for you ). Then you need to read the register data into your app with <whatever> read command in your library.
That is the simplest high level I can give you. Some people (like me) have to read the i2c tutorials *many* times before they (me) have an understanding to use the bus... it really is simple, but at first seems very very confusing... keep persisting persevering and don't give up... it will be a rewarding journey, especially since most interesting sensors are i2c !
Posted: Sat Apr 25, 2015 11:06 am
by rapidograf
MarkHaysHarris777 wrote:Greetings, I understand. Reading the i2c bus is very confusing for everyone; do not feel like you're alone on that one!
you are right.
i know address of device DS3231 .
but how read dtata and convert it to the understandable data .
Posted: Sat Apr 25, 2015 11:07 am
by DougieLawson
Add this
dtoverlay=i2c-rtc,ds3231
to /boot/config.txt reboot and use hwclock to read/write your RTC.
Posted: Sat Apr 25, 2015 11:16 am
... you can try Dougie's config.txt entry... I know I'm going to !
... but if you want to read the data yourself you're going to have to get into the spec sheet on the RTC and understand how its config register works, and how its data registers work; whether they are little-endian or big-endian and whether the data comes back as bytes or string and how your codes will need to convert or translate, if even.
Have you done a google search?
Posted: Sat Apr 25, 2015 11:23 am
by rapidograf
DougieLawson wrote:Add this
Thank you .
and what next i have to do ?
may be you know ample on python for this case ?
and how i turn off internet clock Raspi ?
Posted: Sat Apr 25, 2015 11:56 am
by DougieLawson
To read the RTC use sudo hwclock -r, to set the RTC use sudo hwclock -w, to find out what else you can do with the RTC use hwclock -h.
To disable NTP use sudo update-rc.d ntp disable be aware that the date will revert to 00:00:00 01/01/1970 if the system can't read a valid time from the RTC. Strange things happen when your system does that.
Posted: Sat Apr 25, 2015 3:26 pm
by rapidograf
DougieLawson wrote:To read the RTC use sudo hwclock -r, to set the RTC use sudo hwclock -w, to find out what else you can do with the RTC use hwclock -h.
WOW !!!! thank you .
step by step caveman will have fire and wire ;-)
Posted: Sat Apr 25, 2015 3:37 pm
by rapidograf
Sorry.
may be you know sample how directly read data from memory sells of DS3231 ?
Posted: Sat Apr 25, 2015 3:53 pm
by rapidograf
i added it . but sudo hwclock -h
return only this
pi@raspberrypi ~ $ sudo hwclock -r
hwclock: Cannot access the Hardware Clock via any known method.
hwclock: Use the --debug option to see the details of our search for an access method.
pi@raspberrypi ~ $ hwclock -r
Posted: Sat Apr 25, 2015 8:18 pm
by DougieLawson
rapidograf wrote:may be you know sample how directly read data from memory sells of DS3231 ?
I'd have to read the source code for hwclock, and the ds3231 kernel driver.
Or read a datasheet for the RTC chip. There'll be a bunch of I2C commands needed and data returned from a bunch of I2C registers. It's usually trivial to do that stuff having read the datasheet.
Kernel driver is: https://github.com/raspberrypi/linux/bl ... c-ds1307.c
Posted: Sat Apr 25, 2015 8:45 pm
by rapidograf
mmmm . sorry/ how install kernell driver i open your link but didnot found any hints how dod it :?
Posted: Sat Apr 25, 2015 9:08 pm
by DougieLawson
Posted: Sun Apr 26, 2015 5:14 am
by rapidograf
DougieLawson wrote:Read the datasheet http://datasheets.maximintegrated.com/en/ds/DS3231.pdf
thank you for datasheet .
but anyway , how install which link you gave to me - Kernel driver is: https://github.com/raspberrypi/linux/bl ... c-ds1307.c :?
Posted: Sun Apr 26, 2015 7:02 am
by rapidograf
Last summary.
DS3231 is found by the sudo i2cdetect -y 1 . return 0x68
from registers od DS 3231 i can read data
Seconds 00h= 0b1010100
Minutes 01h= 0b110101
Hours 02h= 0b101
Day of week 03h= 0b1
Date 04h= 0b1
Month 05h= 0b1
Year 06h= 0b0
registered 0x00 , 0x01 , 0x2 changed in time , registered 0x03, 0x04, 0x05 , 0x06 not changed in time.
As adviced Mr Lawson
i add into /boot/config.txt to last lines dtoverlay=i2c-rtc,ds3231 save and reboot.
after reboot i tried use the sudo hwclock -r , this command returned only
by the easy googling i found only advices as connect RTC to kernel before the 2015 , but as you know new version of kernell has totally another methods for run RTC
Of course i give something wrong or miss very small but important step .
somebody help :?
P\S =>
pi@raspberrypi ~ $ sudo hwclock --debug
hwclock from util-linux 2.20.1
hwclock: Open of /dev/rtc failed: No such file or directory
No usable clock interface found.
pi@raspberrypi ~ $
Posted: Sun Apr 26, 2015 7:38 am
by rapidograf
by the Sheakespire's monkey method i setup the RTC and hwclock .
but immidiately i had another problem , i cnat read data from RTC by the i2c registers !!!!
how i can turn off the RTC , that i can use i2c reading from DS 3231 ;-)
yeas -yes i know that you begin thhink ;-)
Posted: Sun Apr 26, 2015 7:46 am
by DougieLawson
sudo apt-get update && sudo apt-get dist-upgrade should get you a kernel with the DT support you need to run with a config.txt entry. Also are you updating the right config.txt? Hold [SHIFT] during boot and use the NOOBS recovery editor.
If the kernel module works you'll get
pi@apollo:~$ sudo i2cdetect -y 1
[sudo] password for pi:
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@apollo:~$
from an i2cdetect command.
Posted: Sun Apr 26, 2015 8:04 am
by rapidograf
DougieLawson wrote:sudo apt-get update && sudo apt-get dist-upgrade should get you a kernel with the DT support you need to run with a config.txt entry. Also are you updating the right config.txt? Hold [SHIFT] during boot and use the NOOBS recovery editor.
Thank you Mr. Lavson
i alreadu unconnect RTC DS 3231 from autoboot and now i can use time from internet and time from registers of DS3231 separately .
i can directly read data from registers and recalculate to understandable data.
Why reason ? because i did not found how make parsing for the hwclock -r returned data ;) i'm not so deep programmer for this case.
Posted: Wed Jul 15, 2015 3:03 pm
by DougieLawson
supra wrote:Do I hafta to added this if I'm using SwitchDoc Lab's code? :?: :?: :?:
No idea, ask the code maintainer.
Posted: Thu Jul 16, 2015 1:13 am
by sommersoft
Obsolete post is obsolete.
Posted: Thu Jul 16, 2015 10:43 am
by DougieLawson
That document is out of date. The device tree support in the kernel supersedes that.
Posted: Thu Jul 16, 2015 2:19 pm
by sommersoft
:arrow:
Posted: Thu Jul 16, 2015 6:12 pm
by DougieLawson
sommersoft wrote:
Oddly enough, it worked flawlessly for me a few days ago...
But the device tree stuff is 1000 times easier.
Posted: Thu Jul 16, 2015 9:50 pm
by sommersoft
DougieLawson wrote:But the device tree stuff is 1000 times easier.
Copy.
Posted: Thu Mar 17, 2016 11:54 pm
by baconater
Try this in the command line:
sudo apt-get install i2c-tools
sudo i2cdetect -y 1
sudo nano /etc/modules
Now add "snd-bcm2835", "i2c-bcm2835", "i2c-dev", and "rtc-ds1307" to the bottom if it isn't there already.
sudo reboot
Plug in your RTC.
After your pi reboots, use
sudo i2cdetect -y 1
The RTC should show up as "UU". If it doesn't, try plugging VCC to 5v instead of 3.3v.
To read the time on the RTC, try
sudo hwclock -r
To set the time on the RTC, first you need to set the time on the Raspberry Pi. Then, use
sudo hwclock -w
to write the Raspberry Pi's time to the RTC.
If all that doesn't work, then try reading this guide:
http://www.raspberrypi-spy.co.uk/2015/0 ... pberry-pi/
