liderbug
glibc detected *** raspimjpeg: double free or corruption
Fri Feb 06, 2015 2:32 am
RP A. So my orig 8GB hit 90+% usage and I want to do more so I got a 16GB card and loaded 2015-01-31-raspbian. raspistill works. Then did http://www.raspberrypi.org/forums/viewtopic.php?t=61771 - .raspimjpeg. Also loaded mjpeg.sh. I've been most of the day fighting
./mjpeg.sh start
Started
root@dwcam:/home/pi/bin# *** glibc detected *** raspimjpeg: double free or corruption (out): 0x01fe3460 ***
Tired, cranky, twisty little passages all alike - Wits End.
cal
liderbug
Re: glibc detected *** raspimjpeg: double free or corruption
Fri Feb 06, 2015 3:20 am
And with that I found the problem - there are 2 "raspimjpeg" downloads out there and I had downloaded the orig one. @#($&!@#$$
I started with "http://www.raspberrypi.org/forums/viewtopic.php?t=61771"
Ended with "http://www.raspberrypi.org/forums/viewt ... 91#p468491" and ya I know I didn't read page as "See Spot run...".
it's been a longgggggggggg day.
JeremPi
Fri Jun 12, 2015 7:51 am
So how did you fixed your problem ?
*** glibc detected *** raspimjpeg: double free or corruption (out): 0x0166ebc0 ***
Return to “Camera board”
