NicoVanDerDussen
Problem with Camera mmal_vc_component_create: failed to crea
Fri Nov 21, 2014 12:02 pm
I have a Raspberry Pi B+ with a PiNoir camera.
I'm using the 9 Sept 2014 Raspian image (not NOOBS)
With SD card 1 all works fine.
With SD Card 2 I repeatedly get this error:
mmal: mmal_vc_component_create: failed to create component 'vc.ril.camera' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component 'vc.ril.camera' (1)
mmal: Failed to create camera component
mmal: main: Failed to create camera component
mmal: Camera is not enabled in this build. Try running "sudo raspi-config" and ensure that "camera" has been enabled
To date I've done the following:
sudo apt-get update & upgrade
Formatted the problem card with SDFormatter V4.0 and loaded teh image again with Win32DiskImager
and tried again - I did enable the camera repeatedly in raspi-config
I have 3 other Pi's with cameras working and this one is the first one I have a problem.
Can't understand why it works with 1 SD card and not with the other :)
What Am I missing?
Nico
Setting up your Raspberry Pi to work with a 3G dongle http://nvdd.info/11gKrsZ
mad-hatter
Re: Problem with Camera mmal_vc_component_create: failed to
Fri Nov 21, 2014 4:29 pm
What about 'sudo apt-get dist-upgrade'.
May need the latest camera progs.
Regards
grahambn
Sat Nov 22, 2014 5:26 am
I have a similar problem. Enabling the camera in raspi-config doesn't seem to survive the reboot. Upgrading the dist didn't help. :(
Return to “Camera board”
