Did the update, got the long-exposure-enabled code, thanks much.6by9 wrote:Those changes already have been released, so just do a "sudo rpi-update"pjwalsh77b wrote:Will the enhancements that allow exposure times > 1s be made available through the general software release process, or do I need to do something special to get them?
In other words, if I just do "sudo apt-get update; sudo apt-get upgrade" will I get the new code?
What about this ? http://www.raspberrypi.org/forums/viewt ... 6&start=63jamesh wrote:For star trails you need very long exposures. The Pi camera can only do up to 6s exposures which are not long enough.
gordon77 wrote:What about this ? http://www.raspberrypi.org/forums/viewt ... 6&start=63
It is stacking the raw images as they are produced, and then creating a JPEG of that.taking 300 images and staging them together
still star trails however produced6by9 wrote:gordon77 wrote:What about this ? http://www.raspberrypi.org/forums/viewt ... 6&start=63It is stacking the raw images as they are produced, and then creating a JPEG of that.taking 300 images and staging them together
There is currently no way on the Pi to produce more than a 6second exposure for a single image. As posted elsewhere, we may get it up to 20s, but that will be the absolute maximum. To get any more you will have to stack them - there is no option.
The poster specifically asked to do it without stacking.gordon77 wrote:still star trails however produced6by9 wrote:gordon77 wrote:What about this ? http://www.raspberrypi.org/forums/viewt ... 6&start=63It is stacking the raw images as they are produced, and then creating a JPEG of that.taking 300 images and staging them together
raspistill --awbgains 1,1 --nopreview --ISO 800 --timelapse 1000 --width 128 --height 128 --shutter 100000 --timeout 180000 --burst --awb off -o %03d_testnew.jpg
raspistill --awbgains 1,1 --nopreview --ISO 800 --timelapse 1000 --width 128 --height 128 --shutter 100000 --timeout 180000 --burst --raw --awb off -o %03d_testnew.jpg
Should have been fixed the other day with commit https://github.com/Hexxeh/rpi-firmware/ ... 9c9a05c2edraspindi wrote:somebody? ok i reproduced the problem on the command line:
when i do:everything works as expected.Code: Select all
When i now include the raw option:Then the first image is ok but all folowing images are just black (the jpeg) and the raw is just noise.Code: Select all
Any ideas? the burst mode in combination with the raw mode would be great to use....
What do you mean?Wolfskin75 wrote:I guess its a question of camera having a better sensors?
sudo rpi-update
jamesh wrote:What do you mean?Wolfskin75 wrote:I guess its a question of camera having a better sensors?
The amount of time required to get a new sensor up and running with decent picture quality is huge. Any camera priced at the level that would actually sell will be of similar performance to the current OV5647. Sony sensors are OK, but more expensive. Never seen a camera module by Nikon.Wolfskin75 wrote:jamesh wrote:What do you mean?Wolfskin75 wrote:I guess its a question of camera having a better sensors?
If we get noise when making long exposures and the camera sensor it relatively high in mega pixels then shouldn't it then be a question of finding a senor than produces less noise in the exposure. Someone like Sony or Nikon make a better camera sensor for the Pi cam.
Since Nikon, Sony, and Omnivision are all limited by the same physics, economics, and NDAs, "better" can only mean a trade-off between themWolfskin75 wrote:.. a question of finding a senor than produces less noise in the exposure. Someone like Sony or Nikon make a better camera sensor for the Pi cam.
raspistill --nopreview -bm -tl 1000 -v -set -ISO 100 -w 1296 -h 972 -awb off -awbg 1,1 -t 180000 -ss 6000000 -o %03d.jpg
001.jpg 027.jpg 040.jpg 052.jpg 065.jpg 077.jpg 090.jpg 103.jpg 115.jpg 128.jpg 140.jpg
Side effect of http://www.raspberrypi.org/forums/viewt ... 75#p600725fehlfarbe wrote:Hi,
is the burst mode already merged with the official raspistill?
Today I tried this after a fresh rpi-update:I'm getting the filesCode: Select all
Which means every image (except the first one) takes ~12s (6s exposure + 6s waiting). I expected 6s for image and 0s waiting in burst mode lik ein post http://www.raspberrypi.org/forums/viewt ... 32#p588432Code: Select all
pi@meteorberry ~ $ raspistill -fp --nopreview -bm -v -set -ISO 100 -awb off -awbg 1.1,1 -t 0 -ss 6000000 -o t_%03d.jpg
raspistill Camera App v1.3.8
Time delay 0, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled no
Full resolution preview Yes
Capture method : Run forever
Preview No, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 100, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'off', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera preview port to video render.
Connecting camera stills port to encoder input port
Enabling encoder output port
Starting capture 1
mmal: Exposure now 5969487, analog gain 256/256, digital gain 256/256
mmal: AWB R=281/256, B=256/256
Finished capture 1
Starting capture 2
Finished capture 2
Starting capture 3
Finished capture 3
-rw-r--r-- 1 pi pi 80585 2014-09-11 13:58:43.850083454 +0200 t_001.jpg
-rw-r--r-- 1 pi pi 80585 2014-09-11 13:58:56.170970217 +0200 t_002.jpg
-rw-r--r-- 1 pi pi 80585 2014-09-11 13:59:08.721873768 +0200 t_003.jpg
-rw-r--r-- 1 pi pi 80585 2014-09-11 13:59:21.262776824 +0200 t_004.jpg
