mdsousa
removing motion blur from moving picamera
Sun Jul 13, 2014 11:53 pm
Hi
I've built a system of two picameras along with some other hardware and storage to collect road data while driving. I've created a blog discussing this project: http://auvrnh.blogspot.com/, and am having one particular problem.
If I speed up the camera's shutter speed using the python command shutter_speed() would that effectively remove the motion blur? I'm collecting right now at a resolution of 1920x1080 at 5fps. I understand that the picamera's shutter_speed depends a lot on the view's illumination which can be a problem on the road with the diversity of light conditions from sun/clouds/shade etc.
Thanks...
towolf
Re: removing motion blur from moving picamera
Wed Jul 16, 2014 3:06 pm
You need to use what raspicam call the "sports" exposure preset.
mdsousa
Thu Jul 17, 2014 10:01 pm
Thanks toworlf,
towolf wrote:You need to use what raspicam call the "sports" exposure preset.
Is there a python analogue to raspicam's sports exposure preset?
waveform80
Sat Jul 19, 2014 9:15 pm
mdsousa wrote:Thanks toworlf,
Yup - that's the exposure_mode attribute in picamera.
Dave.
AndrewS
Wed Jul 23, 2014 10:55 pm
waveform80 wrote:
mdsousa wrote:Is there a python analogue to raspicam's sports exposure preset?
...which is simply documented with "The possible values can be obtained from the PiCamera.EXPOSURE_MODES attribute."
Are the PiCamera.EXPOSURE_MODES listed in the online HTML documentation?
waveform80
Thu Jul 24, 2014 12:46 pm
Not at the moment (because I'm lazy and didn't fancy keeping the list up to date in two places), and I figured anyone interested in the property could just do something like:
$ python
Python 2.7.3 (default, Jan 13 2013, 11:20:46)
[GCC 4.6.3] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import picamera
>>> picamera.PiCamera.EXPOSURE_MODES
{u'auto': 1, u'fireworks': 12, u'verylong': 9, u'fixedfps': 10, u'backlight': 4, u'antishake': 11, u'snow': 7, u'sports': 6, u'nightpreview': 3, u'night': 2, u'beach': 8, u'spotlight': 5}
Still, you're right that it does mean that anyone searching the docs for "sports" won't find anything, so it's probably worth listing the keys in the docs; I'll bung it in a ticket for 1.7.
Dave.
AndrewS
Thu Jul 24, 2014 12:52 pm
waveform80 wrote:
AndrewS wrote:Are the PiCamera.EXPOSURE_MODES listed in the online HTML documentation?
You could modify your documentation-build script to automatically extract the list from the code (along with any other enums where appropriate), and insert it into the documentation? ;)
waveform80
Fri Jul 25, 2014 7:07 pm
Tempting, but I don't know how much reign ReadTheDocs gives projects to run arbitrary code when building docs. I'll try and find out - if it's an option I'll certainly try and take it!
Dave.
Return to “Camera board”
