Mettauk
Embedding Date and Time in Timelapse
Sun Apr 27, 2014 5:33 am
I found a small script to capture stills from Andrew Beck
ROLL=$(cat /var/tlcam/series)
SAVEDIR=/var/tlcam/stills
while [ true ]; do
/opt/vc/bin/raspistill -o $SAVEDIR/$filename
sleep 4;
done;
I want to embed the time in within each captured frame (botom left if poss). can anyone help.
This may have been dealt with but I could not find it in the forum.
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
Re: Embedding Date and Time in Timelapse
Sun Apr 27, 2014 7:51 am
Change
to
raspistill -x -o $SAVEDIR/$filename
adding the -x flag gets EXIF data written to the image, the EXIF data includes the date and time.
This is a doctor free zone.
Mettauk
Sun Apr 27, 2014 8:00 am
Thanks but I want to see the date and time in the image (Pref bottom left) not just in the jpg file data or am i missing something with -x ?
I found imagemagick and can post convert but with thousends of captured images it makes sence to do that at the time of image capture.
#!/bin/bash
for file in *.jpg ; do
convert "$file" -font arial \
-pointsize 72 -fill white -annotate +100+1850 \
%[exif:DateTimeOriginal] "new-${file}"
done
Sun Apr 27, 2014 8:04 am
Just by running raspistill with -x I get
Camera Maker: RaspberryPi
Camera Model: RP_OV5647
Image Date: 2014-04-14 11:27:02 (no TZ)
Color Space: sRGB
GPS Coordinate: undefined, undefined
6by9
Sun Apr 27, 2014 8:06 am
Currently there is no way to do this on the GPU (and all the encoding is done there with no extra requirement on the ARM)
Mettauk
Sun Apr 27, 2014 8:18 am
6by9 wrote:Currently there is no way to do this on the GPU (and all the encoding is done there with no extra requirement on the ARM)
Oh... thanks. :?
mikerr
Tue Apr 29, 2014 4:01 pm
You can avoid losing detail to jpeg compression TWICE by getting raspistill to output a lossless format like BMP,
then only using jpeg after adding the datetime to the image:
raspistill  -n -t 500 -e bmp -o - | convert -pointsize 72 -annotate +30+100 "$(date)" - image.jpg
That does take around 4 seconds to run on a full 2592x1944 frame though !
Mettauk
Tue Apr 29, 2014 8:24 pm
Thanks I have tried
raspistill -w 1280 -h 720 -x -n -e bmp -o - | convert -pointsize 24 -fill white -annotate +30+680 "F1 $(date)" -
It takes around 7-8 seconds between images on medium overclock 256 Pi.
I would like to reduce it down to the 4 seconds or less. Any ideas?
The full code being used is
ROLL=$(cat /var/tlcam/stillsa)
while [ true ]; do
/opt/vc/bin/raspistill -w 1280 -h 720 -x -n -e bmp -o - | convert -pointsize 24 -fill white -annotate +30+680 "F1 $(date)" - $SAVEDIR/$filename
sleep 0;
done;
ethanol100
Wed Apr 30, 2014 9:53 am
Do you finally need jpeg images?
If you just want to look at the annotated images you could create svg images.
The svg image is just a text file which contains a link to the jpeg and a text element.
Creating these svg images is fast and easy. You can i.e. create a template using inkscape and later copy the template and replace the link to the jpeg file and the text only.
So what do you exactly want to do with this pictures? Create a video? Use as security system?
You can not really speed up the process, if you want to annotate the images using jpegs. Saving a full frame image to bmp will take several seconds, because the "encoding" is done on the cpu and more data needs to be copied to the arm side. And imagemagick uses only the cpu to create the final jpg. Only way to speed this up is using a smaller image size(i.e. 640x480 px).
mikerr
Wed Apr 30, 2014 10:33 am
Yes, CPU= slow, GPU = fast
I was having a play with tasanakorn's mmal code this morning to overlay text onto video using GPU
and save the result:
https://github.com/mikerr/rpi-mmal-demo
if you just want the binary:
wget https://www.dropbox.com/s/rboi6nangraccbn/vid_overlay
chmod a+x vid_overlay
./vid_overlay -t 2 -s "$(date)"  > test.h264
omxplayer test.h264
-t is the duration of clip in seconds
-s is the overlay string
Stills should be similar, I'll look later.
6by9
Wed Apr 30, 2014 2:26 pm
That code on mikerr's github should be usable as a basis for JPEG encode too.
For video encode the GPU will be doing a few more conversions/copies but otherwise should be fine.
On stills you will lose EXIF and thumbnail as the metadata required only gets passed on MMAL_ENCODING_OPAQUE buffers. Stick with MMAL_ENCODING_I420 if you want to avoid extra conversions. You'll also have a couple of very large buffers being passed around (5MPix I420 = 7.5MB), so memory may become a little tight under some situations.
mikerr
Wed May 07, 2014 2:02 pm
Forgot to update this with the stills version..
wget https://www.dropbox.com/s/ydxz55y0nt9b8q4/still_overlay
chmod a+x still_overlay
./still_overlay -s "$(date)"  > test.jpg
Mettauk wrote: It takes around 7-8 seconds between images on medium overclock 256 Pi.
The above now runs in 0.5 sec including capture :lol:
rleyden
Wed May 07, 2014 5:02 pm
mikerr wrote:Forgot to update this with the stills version..
Very nice, thanks.
How hard would it be to include rotation and exposure into still_overlay?
I have a Pi Noir setup to capture wildlife at night. I get great exposures with a near-IR diode light source and using "-ex night" and raspistill. The captures take more than a second but that's OK. Using raspivid gave me unpredictable results. I have a PIR sensor that I can use to trigger the camera. But, given the slow capture rate, it was be better to just capture continuously. I use mencoder to string the frames together so I can quickly review it for wildlife. Including a timestamp on the frame makes it easier to go back and find the frames of most interest. Right now, running flat out, I manage 4 frames a minute. Faster would increase the odds of getting an interesting shot.
mikerr
Wed May 07, 2014 5:25 pm
Very nice, thanks.
Not too hard, but better would be to move the overlay code into raspistill, so you get all the options available.
Mettauk
Wed May 07, 2014 6:39 pm
Thanks for this but I'm not sure how to incorperate this code into the stills capture I have been using?
while [ true ]; do
sleep 0;
done;
Which as said before take 7-8 seconds between images. So getting this down seems ideal.
algorithm
Wed May 07, 2014 8:26 pm
PHP on a web server on the Pi can easily keep up with raspistill time lapse shots every 2 seconds (which is better than re-starting raspistill every x seconds) for 800x600 jpegs in memory. See http://dronkert.net/rpi/webcam.html
mikerr
Wed May 07, 2014 11:47 pm
Mettauk wrote: Thanks for this but I'm not sure how to incorporate this code into the stills capture I have been using?
Your new script would be something like:
while [ true ]; do
/home/pi/still_overlay -t 3 -s "F1 $(date)"  > $SAVEDIR/$filename
sleep 0;
done;
I ran that and got 60 timestamped images in 60 seconds:
stephanl
Tue Aug 23, 2016 1:44 pm
Hello Mike,
I was trying to compile your source of the code you modified for still capture with text overlay.
I did it on a model 2 b+ with an up to date patched version of jessie. When issuing the make command
the following errors stopped make from continuing:
pi@raspberrypi:~/src/raspberrypi/build/rpi-mmal-demo $ make
Scanning dependencies of target mmal_buffer_demo
[ 20%] Building C object CMakeFiles/mmal_buffer_demo.dir/buffer_demo.c.o
Linking C executable mmal_buffer_demo
[ 20%] Built target mmal_buffer_demo
Scanning dependencies of target mmal_opencv_demo
[ 40%] Building C object CMakeFiles/mmal_opencv_demo.dir/opencv_demo.c.o
Linking C executable mmal_opencv_demo
/usr/bin/ld: CMakeFiles/mmal_opencv_demo.dir/opencv_demo.c.o: undefined reference to symbol 'sem_post@@GLIBC_2.4'
//lib/arm-linux-gnueabihf/libpthread.so.0: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
CMakeFiles/mmal_opencv_demo.dir/build.make:114: recipe for target 'mmal_opencv_demo' failed
make[2]: *** [mmal_opencv_demo] Error 1
CMakeFiles/Makefile2:95: recipe for target 'CMakeFiles/mmal_opencv_demo.dir/all' failed
make[1]: *** [CMakeFiles/mmal_opencv_demo.dir/all] Error 2
Makefile:76: recipe for target 'all' failed
make: *** [all] Error 2
Could you please hint me in the right direction how solve this?
Any help much appreaciated.
Regards
Stephan
stephanl
Mon Sep 12, 2016 9:44 am
I did get the code compiled by adding the missing links to the corresponding executables in the CMakelist.txt.
That was not so difficult. But when still_overlay is executed the time stamp does not appear on every jpg. I am not sure why that is. Could it be that the rasclock module is interfering? My guess would be No. I tried it on jessie as well on wheezy. On wheezy I got one jpg with time stamp :D
I upped the GPUs memory with no difference.
The file names though are with the corresponding time stamp with a two hour difference.
I will try to remove fake-hwclock and see if that makes difference.
I also was wondering which bit in still_overlay writes the time stamp overlay onto the jpg?
Where would I add that to raspistill?
Any help much appreciated
mikerr
Mon Sep 12, 2016 8:43 pm
My code above was written before raspistill had annotation built in, nowadays you can do:
show date and timestamped image:
https://www.raspberrypi.org/documentati ... /camera.md
stephanl
Tue Sep 13, 2016 9:22 am
That decomplicates things.
Thx
Return to “Camera board”
