allentiak
IR/non-IR mode software-switch for camera?
Fri Feb 07, 2014 9:02 pm
I'm about to buy a RaspberryPi with a camera module. My main immediate goal is experimenting with video (in both IR and non-IR modes).
However, I don't see the point in buying two cameras when I will only be able to use one at any given moment...
As the IR module is a stripped-down version of the non-IR one, I assume the non-IR module should have (potential) IR capabilities. Am I right?
If so, is there a way to switch IR/non-IR video modes (by software!) within a single (in principle, non-IR) camera module?
It would be great if I could simply buy one camera to record in both IR and non-IR modes...
Cheers,
Leandro
poing
Re: IR/non-IR mode software-switch for camera?
Sat Feb 08, 2014 12:03 am
The only difference is that the IR camera lacks a physical IR filter and thus also records (in normal photography unwanted) IR light. You can buy an IR block filter and have that move in front of the lens by a servo.
redhawk
Sat Feb 08, 2014 12:09 am
Just be aware that IR block filters don't come cheap so it would probably make more sense to buy both types of cameras instead of one + external filter.
Richard S.
allentiak
Fri Feb 14, 2014 1:45 pm
Thanks both of you for your answers.
jbeale
Fri Feb 14, 2014 3:04 pm
Just FYI, you can buy 2 pieces of 9.5 mm diameter IR filter (1% cutoff at 700 nm) for $6.50 with shipping included. The servo to move it in front the camera probably costs more. http://www.ebay.com/itm/9-5mm-Optical-U ... 0529710153
Return to “Camera board”
