leofric
issue with raspistill (&vid) saving to mounted network drive
Fri Jan 17, 2014 10:57 am
Hi - been around computers for years but very new to raspberry pi and linux.
Help please - going in circles.
I have mounted the public folder on a wired network Windows PC as PiPics The folder has read/write access.
On the Pi I can browse the contents of the PC folder by cd /mmt/PiPics and see the contents ok.
Nano can write a text file to the windows folder with no problem.
I can't get raspistill to save to it.
Using raspistill -o //mnt/PiPics/test.jpg
or raspistill -o /mnt/PiPics/test.jpg from the root
or if I change to the mmt/PiPics directory and use the same or
raspistill -o test.jpg I get the same error
The error generated is;
mmal: main: error opening output file: test.jpg
Very odd as Nano saves to the drive and raspistill works great on the Pi.
I must be missing something very obvious.
Honsolgen
Re: issue with raspistill (&vid) saving to mounted network d
Fri Jan 17, 2014 12:39 pm
two lines in a shell script
capture the image with raspistill locally
then copy the image to your mounted device
leofric
Fri Jan 17, 2014 4:03 pm
Thanks for the prompt reply.
I could do as you suggest but I don't understand why raspistill can't save directly to the drive as other apps can.
Honsolgen
Fri Jan 17, 2014 4:43 pm
maybe it´s because accessing the user-space filesystem SMB is not implemented within raspistill.
At least I can tell:
I have an sshfs filesystem mounted on my pi. And I just tried it with raspistill.
Works flawless
leofric
Fri Jan 17, 2014 5:09 pm
problem solved .... !
:oops:
I thought I was at the root but wasn't.
sudo raspistill -o /mnt/PiPics/Testpic.jpg
works fine and saves the image directly to the mapped drive on the networked PC.
Return to “Camera board”
