Page 75 of 204
Re: RPi Cam Web Interface
Posted: Wed Apr 15, 2015 4:52 pm
by btidey
0lly wrote:
I can confirm that it does not run with them.
I'm back to Firefox 36.0.4
OK. Because of the difficulties in some browsers I have made the following changes which are in the repo.
1. Revert default operation to the image at a time preview as used before
2. Left MJPEG stream support in as well
3. Introduced a new button in System which toggles between MJPEG stream and Default Stream (image by image
4. Retain Stream mode in browser cookie.
There are some MJPEG stream improvements which will also be merged in shortly.
That let me have MJPEG streaming in Chrome plus Default Streaming in 37.01 Firefox on the same platform.
Posted: Wed Apr 15, 2015 7:05 pm
by morticiaskeeper
New update tested on Chrome & Safari in iOS. Livestream now shows a still frame, only updating when prompted.
Chrome in Android works fine.
Would it be the iOS version? I'm using 7.1.2 the latest for the iPad2 before the 8 upgrade.
Edit. Now also tried in Opera, Dolphin & private browser. Same result in all.
Posted: Wed Apr 15, 2015 7:19 pm
by silvanmelchior
Hello
Those of you who use the circular buffer with a size of 4000 or lower should update to version 5.1.3, because otherwise your logfile could get overflowed with iframe-error-messages.
The problem is that the h264-encoder outputs an iframe every 60 frames per default, so if the buffer is too small to hold at least one of these frames, the whole content of the buffer gets useless. The new version fits the intraperiod to the size of the buffer and changes it back, once recording started. Additionally, the new version checks wheter there are enough iframes (at least 4) in the buffer and otherwise asks the encoder for a new one. This way, it can be guaranteed that at least 75% of the buffer is decodable.
I hope the new version fixes the problem
Posted: Wed Apr 15, 2015 7:56 pm
by drhitchcock
Hi there!
After I run the initial ./RPi_Cam_Web_Interface_Installer.sh after cloning the Github repo I get the error message "No or invalid option selected". What does this error message mean?
I have the Infrared Pi Camera board attached and it runs fine with raspistill and raspivid.
Many thanks,
Dr Hitchcock.
Posted: Wed Apr 15, 2015 7:58 pm
by silvanmelchior
drhitchcock wrote:Hi there!
Many thanks,
Dr Hitchcock.
You need to type ./RPi_Cam_Web_Interface_Installer.sh
install
Posted: Wed Apr 15, 2015 8:37 pm
by Blairvoyach
Sorry if this a FAQ, I have searched but I'm stumped.and a newbie to Raspberry Pi
When I come clone the RPi_Cam_Web_Interface.git from Silvan's site, I am asked for a username and password which I obviously do not posess.
Can someone please give me a hint on what to try ?
Posted: Wed Apr 15, 2015 9:11 pm
by btidey
morticiaskeeper wrote:New update tested on Chrome & Safari in iOS. Livestream now shows a still frame, only updating when prompted.
Were you getting a livestream OK before the recent MJPEG stream change? Is the system menu on main page now showing a blue button called MJPEG-Stream. If it is then it should be operating the same way as before.
Posted: Thu Apr 16, 2015 4:58 am
by drhitchcock
Oh man! What a dingus. Can I blame baby brain for that?
silvanmelchior wrote:drhitchcock wrote:Hi there!
Many thanks,
Dr Hitchcock.
install
Posted: Thu Apr 16, 2015 5:00 am
by silvanmelchior
Blairvoyach wrote:Sorry if this a FAQ, I have searched but I'm stumped.and a newbie to Raspberry Pi
Sounds strange, could you post your console-input and the answer?
Posted: Thu Apr 16, 2015 5:45 am
by Blairvoyach
I'm probably doing something very wrong but this is what I get
pi@raspberrypi ~ $ git clone
https://github.com/silvanmechior/RPi_Cam_Web_Interf
ace.git
Cloning into 'RPi_Cam_Web_Interface'...
Username for '
https://github.com':
Password for '
fatal: Authentication failed
Posted: Thu Apr 16, 2015 5:49 am
by Blairvoyach
Must have been something wierd I was doing Silvan, now it it working
Posted: Thu Apr 16, 2015 5:57 am
by silvanmelchior
Blairvoyach wrote:Must have been something wierd I was doing Silvan, now it it working
Great!
Posted: Thu Apr 16, 2015 6:33 am
by morticiaskeeper
Yes, it was working fine before the change. The blue button works, on iOS it switches from the single shot livestream to the loading message, on Android it switches from livestream to the new smoother livestream.
Posted: Thu Apr 16, 2015 6:48 am
by morticiaskeeper
Now this is getting confusing!
I've just done a side by side test to show the problem to my wife. We used an iPad and an Android Hudl2. The Android showed live video on both settings, the iPad showed LOADING on mjpeg and a still frame on default.
I closed the iPad cover down into standby mode. Opened it up again and it now gives live video
Safari doesn't seem to be able to change out of mjpeg, giving LOADING even after switching to default.
Posted: Thu Apr 16, 2015 8:16 am
by jussi24
I did made an update this minutes and I don't see the switching button. Isn't it rolled out by now? What version number will have the alternate streaming switch?
EDIT: now it's there. Was a matter of cache or some other strange thing...
"Real" mjpeg is very appreciated! So I will have the chance to view the stream with standard players like VLC. What is the URL to bind on the pushed mjpeg stream?
Thanks a lot!
Juergen ("follower" of raspimjpeg since this thread contained only 5 pages...)
Posted: Thu Apr 16, 2015 8:18 am
by silvanmelchior
Thanks a lot!
It should be version 5.1.3. Please check if your browser cache is the problem by updating with shift+F5
Posted: Thu Apr 16, 2015 8:21 am
by jussi24
It's there now, thanks! A cache thing or own "competence" or whatever...
Is there an URL where the pushed mjpeg stream is available for other viewers?
Thanks!
Posted: Thu Apr 16, 2015 8:30 am
by jussi24
Answer to my own question:
http://[your URL here]/cam_pic_new.php?
workes fine in VLC!
Posted: Thu Apr 16, 2015 8:59 am
by btidey
morticiaskeeper wrote:Now this is getting confusing!
Confusing indeed! Couple of comments.
These changes like others do require the javascript to be updated and some browsers are reluctant to do that preferring to use a cached version. Normally there a forced refresh will do that. Otherwise there is normally a facility to clear out browser caches which will work.
The stream switching does rely on cookies to hold the setting so that must be enabled in the browser.
If you can view page source one can also check the stream switching by looking near the top
In the default image by image mode there should be a script call setTimeout('init(0);', 100) When in MJPEG mode this should be setTimeout('init(1);', 100).
Posted: Thu Apr 16, 2015 10:09 am
by Gary Littlemore
btidey wrote:Gary Littlemore wrote:"Feature Request"
I'd like to be able to boot the 'RPi Cam Web Interface' as normal and be able to configure a timelapse job with the following, runtime X minutes, taking a picture every X milliseconds, once the runtime X minutes has completed it automatically safely shuts down and only does this again once it’s reconfigured again. So the next boot after the job has been ran it boots as normal. Not sure if this is going to be possible, I'm looking to setup up the job and then boot a pi remotely and the job run.
You can do this today within context of RPi Cam by using the PIPE controls from other programs like a bash script or python. For example, assuming the lapse delay is set up then a bash script which does
echo -n 'tl 1' >/var/www/FIFO
sleep 20m
echo -n 'tl 0' >/var/www/FIFO
would start the time lapse wait 20 minutes and then stop it.
As mentioned if you want to get picture closer than about a second then you are better using a slow fps video. Same technique could be used for starting and stopping that.
If you actually want to initiate the whole process from the web interface by manually pushing a button then that is a separate request and one maybe best done by a general run script button rather than making it specific to just one use.
I'd like to be able to configure the runtime and frames per millisecond/second and shutdown, to connect back up to a power bank and it boot to the settings I configured and shut down after its completed. Have little knowledge of linux I don't know how/what bash is.
Posted: Thu Apr 16, 2015 5:49 pm
by btidey
The documentation material that was in the RPiCam.pdf has been moved to the wiki
http://elinux.org/RPi-Cam-Web-Interface and removed from the code.
This makes it easier to maintain across multiple contributors.
Posted: Thu Apr 16, 2015 5:56 pm
by morticiaskeeper
Cookies are accepted.
In Apple land, the user mustn't be allowed to do anything too far removed from the way Apple want you to do it!
So we can't look at the page source:-)
It seems to be very erratic, sometimes LOADING appears, sometimes the livestream shows. Sometimes it streams, sometimes it shows a still frame. Putting the iPad to sleep, even for a second seems to trigger streaming rather than still frame, but refreshing the page doesn't.
I think it's an Apple foible. Luckily I've always got and Android in my pocket.
Posted: Thu Apr 16, 2015 6:10 pm
by btidey
I suspect you are going to have learn at least some simple coding or scripting and configuration to achieve this. You can use one of several camera applications including RPiCam Web to achieve the basic functionality of performing a sequence of time lapse or slow fps video recording.
The extra parts you will need are setting up a simple program or script to do the basic work and inserting it into the boot sequence.
None of this is particularly complex once you get to learn a few basics.
bash is one of the scripting shells a bit like a bat file in Windows. There are lots of tutorials on the web and for what we are talking about here it is very straightforward.
For example something like this (untested)
#!/bin/bash
# Set up duration here- 20 minutes
LAPSETIME=20m
#make sure everything is going by waiting 20 seconds
sleep 20
#Start the time lapse
sleep $LAPSETIME
#stop the time lapse
#and close down, wait for a bit to make sure all is finished.
sleep 10
sudo shutdown -h now
Posted: Thu Apr 16, 2015 6:32 pm
by btidey
If it was working before the change to MJPEG then it worries me a bit that the stream selection method isn't fully compatible as in Default mode it should be identical to how it was before.
If you wanted to pursue it further then the attached zip has the two files of interest from just before the change was made. I.e. when it was 'working'.
If you want to try this just as a test then put the index.php into /var/www and script.js into /var/www/js. You may want to move the originals first to make it easier to restore. I'd certainly be interested if that works but the current one doesn't.
Posted: Thu Apr 16, 2015 7:18 pm
by morticiaskeeper
Robert
I've just copied those files back to the Raspi.
Chrome on iOS now works fine.
Safari worked, but was a little slow. never using Safari, that may be normal!
