andrew.p.r
Problems with camera board
Mon Nov 04, 2013 1:18 pm
I've recently purchased a camera board for my pi i've run all the updates and updated the firmware using the commands below
sudo apt-get update
sudo apt-get upgrade
sudo rpi-upgrade
I then rebooted and ran
raspi-config
to enable the camera.
Then ran
this turned the red led on the camera board on and gave me the following output
raspistill Camera App v1.3.4
Time delay 5000, Raw no
Thumbnail enabled Yes, width 64, height 48, quality 35
Link to latest frame enabled  no
Full resolution preview No
Capture method : Single capture
Preview Yes, Full screen Yes
Preview window 0,0,1024,768
Opacity 255
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
Camera component done
Encoder component done
Starting component connection stage
Connecting camera stills port to encoder input port
Enabling encoder output port
Starting capture 0
no preview window has come up and the pi has stopped here.
Any hint or tips as to anything that I've done wrong??
Andrew
Re: Problems with camera board
Mon Nov 04, 2013 1:57 pm
Double check all the connections, including the one from the module to the camera PCB itself, that comes sometimes come undone.
What power supply are you using?
andrew.p.r
Mon Nov 04, 2013 2:20 pm
I've checked all the connections and they all seem secure.
Currently using and iPhone power adaptor.
Andrew
andrew.p.r
Mon Nov 04, 2013 3:22 pm
Just to say i've also tried this with an iPad power supply (2.1A @ 5V)
Andrew
gordon77
Mon Nov 04, 2013 5:33 pm
Seeing you have done all the upgrades is it worth trying the latest version of raspistill?
$ cd
$ sudo apt-get install build-essential git cmake
$ git clone https://github.com/raspberrypi/userland.git
$ cd userland
$ git checkout master
$ ./buildme
andrew.p.r
Tue Nov 05, 2013 10:36 am
Thanks everyone.
Still no joy, think this maybe fault going to speak to my supplier about getting a replacement.
I know that it's not had a static discharge as i work in a computer repair shop and we have an ESD safe area.
Andrew
pluggy
Tue Nov 05, 2013 11:22 am
Check the voltage across the test points, the Power supply may be good, but the lead you're using may not be up to it, the camera board has a serious current dependency. It ups the power requirement quite significantly.
Tue Nov 05, 2013 11:34 am
200-250mA.
shuckle
Tue Nov 05, 2013 11:48 am
That 200mA really seems to make a difference.
Before the camera, I could just throw any power source to Pi and it just worked. Never any problems. I even measured low voltages (like 4,5 V from the TP1/TP2), but system still worked reliably.
But after connecting the camera, it suddenly was more difficult and needed more quality on power. I really need to reach the 4,8V before it works properly.
Tue Nov 05, 2013 12:35 pm
shuckle wrote:That 200mA really seems to make a difference.
200mA is another 30% or so. It's nothing the Raspi can change - camera modules are simply very thirsty. When you think about it, there are 5Millions pixel points each with diodes, transistors, capacitors etc, then a bunch more to handle the data addressing. That's a lot of silicon, all of which uses power, and all the time the camera is on - no sneaky power management possible.
Reference....
The 6502 microprocessor has 3510 transistors
The AMD K5 Processor has 4.3M transistors
The ARMv7 has 500k transistors
The camera module has at least 5M transistors...
kaos
Tue Nov 05, 2013 12:54 pm
Not that I've had any power supply problems personally, but judging from the various posts in this forum, I suspect that this is not only a question of extra power required, but also that the camera module is more sensitive to low voltage than the Raspi itself. As Shuckle pointed out, the Raspi seems to chuck along quite happily on voltages as low as 4.5V, but the camera requires full TTL spec; 5V +/- 5%, or very close to it. I don't think there is anything to be done about that though; we just have to ensure that our power supplies (including cables) can deliver enough juice without voltage sag. Imo, 5V 1A should be considered a practical minimum for a Raspi + camera + a couple of low power peripherals (f.x. mouse and keyboard). In an ideal world, ensuring this should be as simple as reading the label on the power supply to check if it's up to spec, but unfortunately not all supplies live up to the promise of their labeling :( .
Regards, Kári.
Tue Nov 05, 2013 2:58 pm
kaos wrote:Not that I've had any power supply problems personally, but judging from the various posts in this forum, I suspect that this is not only a question of extra power required, but also that the camera module is more sensitive to low voltage than the Raspi itself. As Shuckle pointed out, the Raspi seems to chuck along quite happily on voltages as low as 4.5V, but the camera requires full TTL spec; 5V +/- 5%, or very close to it. I don't think there is anything to be done about that though; we just have to ensure that our power supplies (including cables) can deliver enough juice without voltage sag. Imo, 5V 1A should be considered a practical minimum for a Raspi + camera + a couple of low power peripherals (f.x. mouse and keyboard). In an ideal world, ensuring this should be as simple as reading the label on the power supply to check if it's up to spec, but unfortunately not all supplies live up to the promise of their labeling :( .
Regards, Kári.
Not sure. It's certainly possible, but there are so many links in the chain that need adequate power it difficult to tell where the weak link may be.
andrew.p.r
Mon Nov 11, 2013 12:13 pm
Just to wrap this up i've received a replacement board and this is now working.
Thanks to everyone that suggested fixes though.
Andrew
Mon Nov 11, 2013 12:20 pm
Good news! Enjoy!
Return to “Camera board”
