motion mmal and email
Posted: Fri May 31, 2013 9:59 pm
by dpguest
I have dozencrows wonderful adaptation of motion running on my pi. It fires up the pi camera and captures motion when it occurs. It creates a jpg file from the "center" of the motion detected, and an avi movie.
I have mail installed and the following works:
echo 'hi' | mail -s 'Sample Mail' <email address>
If I place this statement in place of value in the on_picture_save, et
; on_picture_save echo 'hi' | mail -s 'Sample Mail' <email address>
I do not get the email when the picture is saved. What am I missing?
thanks....
Re: motion mmal and email
Posted: Sat Jun 01, 2013 12:53 pm
by dozencrows
Try removing the leading semi-colon from your on_picture_save line, giving you:
That semi-colon makes the line into a "comment" - i.e. it doesn't get read by motion. Taking it out should make it work (assuming you've got the mail side of things set up).
Posted: Sat Jun 01, 2013 7:51 pm
by LBS
I've just got my camera and I'm trying to get motion running with the pi camera.
What setting are you using in motion.conf for videodevice?
Posted: Sun Jun 02, 2013 2:22 pm
by dozencrows
Hi LBS!
There are a few ways to do this - you can set your Pi camera up as a webcam via a script triggered from a web server running on the Pi, then configure motion to read from that. See this thread for more: http://www.raspberrypi.org/phpBB3/viewt ... 43&t=43844
Or you can try my customised version of motion which uses the Pi camera directly - read this thread for more info: http://www.raspberrypi.org/phpBB3/viewt ... 43&t=44966
