texy
Re: Using VLC to stream from the camera - Help needed
Thu May 23, 2013 9:12 am
Hi
the -n option works if you modify the code an recompile, which I have done. Details here :
http://www.raspberrypi.org/phpBB3/viewt ... 90#p350486
However, just in case I have cocked-up, I may try a fresh image tonight and start again.
Texy
alexeames
Thu May 23, 2013 9:20 am
ludespeedny wrote:Has anyone been able to stream to a Nexus 7? I am using 2 VLC apps and neither one of them is able to view the stream, but I can view it on my PC via http and rtsp
I know a guy who wrote a blog specifically to address that issue. ;)
http://raspi.tv/2013/how-to-stream-vide ... -using-vlc
Alex Eames RasPi.TV, RasP.iO
alexeames
Thu May 23, 2013 9:25 am
LeoWhite wrote: My camera board is currently connected up to a 512MB Model B I ordered at the same time. I might try connecting up to my Model A or one of my earlier 256MB Model Bs to see if I notice any stability issues with them.
Leo
I hooked one up to a model A last night and noticed a bit of stuttering (direct on the monitor) while recording 1080p. Changed power supply to a battery/reg good for 2A+. Still occurred. I think it's the inferior Silicon Power class 4 SD card I'm using in that one. Will test that theory later by swapping for the other one (Lexar premium class 10.)
[edit]Theory shot to pieces. My model A stutters even with the good card (card image is cloned). So I don't know what the issue is here.[/edit]
[further edit]I think it's a power issue. I just tried a different model B powered through the micro USB socket - with the crappy SD card. I got stuttering (i.e. dropouts). Measuring across the electrolytic cap, it was about 4.89 idle and 4.69V when recording.
I power my RasPiCamcorder directly to the P1 power/GND pins, so tried that with this test, removing the USB lead. Using the same reg that puts out 5.15V no load. In use it was 5.01V and the stuttering stopped.
So I think I'll be using that approach in future for 1080p recordings.[/further edit]
ludespeedny
Thu May 23, 2013 1:18 pm
Yeah, I actually used that blog to try, but there are a lot of VLC players on the app store so I picked 2 I thought would work.
I tries VLC Direct Pro, and Joe's VLC and they didn't work. I also tried MX Player, but no success.
Could you point me to the link for the VLC you use that works?
LeoWhite
Thu May 23, 2013 1:27 pm
ludespeedny wrote:Yeah, I actually used that blog to try, but there are a lot of VLC players on the app store so I picked 2 I thought would work.
I use https://play.google.com/store/apps/deta ... betav7neon on my Nexus 7.
Leo
ludespeedny
Thu May 23, 2013 1:39 pm
That is odd, it says it is incompatible with my device and is not available in my country. I am currently in the US.
LeoWhite
Thu May 23, 2013 1:44 pm
ludespeedny wrote:That is odd, it says it is incompatible with my device and is not available in my country. I am currently in the US.
Hmm, no idea on that one then. I'm in the UK but wouldn't have expected it to be limited by region in that way. I also have it installed on my phone and Transformer Infinity
I guess could try doing a search for 'videolabs' or similar on the US store and see if they have it under another name?
ludespeedny
Thu May 23, 2013 1:58 pm
I do have a VPN in the UK so maybe if I connect to that I could install it. I'll try later when home.
alexeames
Thu May 23, 2013 2:05 pm
You must have missed this bit...
"On the Nexus, or other android device, go to Google Play and install “VLC for Android Beta”. Don’t worry about all the Beta warnings. The world won’t end and it does work OK. :)"
Oh, catching up with the thread I see that you have "territorial issues". Hope you get them solved. :D
ludespeedny
Thu May 23, 2013 2:09 pm
Yeah, I'll give it a shot, maybe it will install even though I have territorial issues :)
ludespeedny
Thu May 23, 2013 2:17 pm
I am unable to get a steady stream. I can't get RTSP working outside my internal network, but can get HTTP working, the problem is it seems to run for a second and stop until it reloads and then stops again (just looks like a pic and not showing any motion).
Here is the streaming command I am using: raspivid -vf -w 640 -h 360 -o - -t -1 |cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=:8554}' :demux=h264
my internet speeds are 10mbps down and 1 up
alexeames
Thu May 23, 2013 3:15 pm
Have you tried it on a PC? I found my Pis could do 720p@25 fps to my Win7 PC but the Nexus couldn't handle anywhere near that.
ludespeedny
Thu May 23, 2013 3:26 pm
Yeah, I am mainly accessing from PC since I can't on my nexus 7 yet.
ludespeedny
Thu May 23, 2013 3:54 pm
Here is a link so you can see the problem. I am running 640x360 25fps
I get video that moves then stops, then moves again. Do you get the same result?
FFAMax
Thu May 23, 2013 3:58 pm
ludespeedny wrote:Here is a link so you can see the problem. I am running 640x360 25fps
http://72.135.99.235:8554
Write here full comand which you execute at Rapberry Pi
ludespeedny
Thu May 23, 2013 4:02 pm
raspivid -vf -w 640 -h 360 -fps 25 -o - -t -1 |cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=:8554}' :demux=h264
FFAMax
Thu May 23, 2013 4:03 pm
ludespeedny wrote:raspivid -vf -w 640 -h 360 -fps 25 -o - -t -1 |cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=:8554}' :demux=h264
Try run this: raspivid -vf -w 640 -h 360 -o - -t -1 |cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=:8554}' :demux=h264
ludespeedny
Thu May 23, 2013 4:08 pm
Running that now, no change
ludespeedny
Is it possible to increase the buffer on the pi so that it is more stable? Would that change anything?
FFAMax
Thu May 23, 2013 4:15 pm
ludespeedny wrote:Is it possible to increase the buffer on the pi so that it is more stable? Would that change anything?
Yes, i see, it's does not help
I do not know your real internet connection speed... try to decrease heigh, width. Use 80x60 - for example. It's just for test.
Also you can try this command - it work for me.
raspivid -fps 30 -w 640 -h 480 -t 999999 --hflip -o - | cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts{use-key-frames},dst=:8554}' :demux=h264
FFAMax
Thu May 23, 2013 4:18 pm
Also you must know that now all guys from this forum trying to open your stream and it's not good =)
ludespeedny
Thu May 23, 2013 4:21 pm
yeah, lol
I will prob change the port shortly.
It seems to disconnect me when someone else views the stream so I am not sure if more than one person can view at a time.
alexeames
Thu May 23, 2013 4:23 pm
Yes it's a bit stop-start. What do you get when you run it within your own LAN? I would assume that would be a connection speed issue. Do you get better results with the Pi on Ethernet? In which case it could be a wireless issue.
It's very grainy - or are you shooting through a wire mesh?
FFAMax
Thu May 23, 2013 4:24 pm
ludespeedny wrote:yeah, lol
Yes, it's must work with many streams (but look at CPU usage - uptime - load average)
FFAMax
Thu May 23, 2013 4:27 pm
Yes, i guess too that problem with network connection. We will get new information when resolution will be decreased
Return to “Camera board”
