momentum wrote:Update: I switched to my 512 RPi and it worked instantly. Something is foul with my 256.
Update 2: I switched my 5m power cable with a short 1m power cable and it now works fine on both the 512 and 256 RPi. I still have the "Packet with too strange dts ... "
I ran into issues like that when getting a USB Web Camera to work. The power lead was dropping enough voltage that the RPi was reading 4.75v across the test points. A shorter power lead made the problem go away.
The V2 boards seem much better in this regards, using the original power lead my Model A reported exactly 5V.
momentum wrote:
It streams fine local and external.
I do however receive many "packet with too strange dts ... " msg's. These seem to appear more during dynamic movements of the camera.
Anyone know how to fix this?
Streaming via RTP/RTSP seems to avoid those messages, but then its hard to stream outside your local network. Not sure if its down to VLC having more work to do when HTTP streaming and occasionally drops bytes from the camera stream...
