Page 2 of 2
Re: Getting Streaming working to a PC
Posted: Fri May 17, 2013 9:45 am
by Longbow
RexRoper wrote:Update 2: After a bit of web searching I found a Win 32/64Bit download for netcat that solved my issues on my WinXP box. No change on the Win8 boxes. Both 32Bit and 64Bit Win8 fail with the same error as above. I will test Win 7 tomorrow. netcat for Win 32/64Bit can be found at:
http://eternallybored.org/misc/netcat/
This solved it for me too, I downloaded the 1.11 version and it works.
Posted: Fri May 17, 2013 10:54 pm
by towolf
New style of HTTP streaming to iDevices and Android described here: http://www.raspberrypi.org/phpBB3/viewt ... 4&p=351398
Posted: Sat May 18, 2013 3:15 pm
by Unhban
Just got mine working OK with my PC, but have found an unusual effect ('feature'?) with Mplayer.
If I use my mouse wheel a series of white squares appear across the screen. They seem to do nothing. However, I've found that if I turn the mouse wheel towards me the time between movement in real life and shown on the screen increases. Whereas, if I turn the wheel away from me the delay decreases to vitually zero.
BTW, I have the -cache setting on the PC set to 4096 (Vista). On the Pi I had to add an -ex night setting, otherwise the pic was quite grainy. Also added a -br 55 setting, otherwise the blacks were crushed.
So my final line (so far!) looks like :
raspivid -t 999999 -hf -ex night -br 55 -o - | nc 192.168.1.65 5001
BTW, the IP Address is the one for your PC and not your Pi..... :P
Unh.
Posted: Sat May 18, 2013 4:47 pm
by LeoWhite
I've finally managed to get streaming workign using vlc and rtp. Seems a little more stable than using http (and I never got netcat/mplayer working under Window!
Running raspivid -o - -t 99999 |cvlc -vvv stream:///dev/stdin --sout '#rtp{sdp=rtsp://:8554/}' :demux=h264
Lets me then play the stream using VLC in windows by Network Streaming from rtsp://<IP of RPi>:8554/
This gets me a step closer to getting better streaming from my BigTraks!
Posted: Sat May 18, 2013 8:53 pm
by ProgDrums
LeoWhite wrote:I've finally managed to get streaming workign using vlc and rtp. Seems a little more stable than using http (and I never got netcat/mplayer working under Window!
This won't work for me. VLC comes up with the following error.
Connection failed:
VLC could not connect to "192.168.1.51:8554".
The IP is definitely right as I've double checked with ifconfig.
EDIT: Cancel that. It's working after a reboot of the PC.
Posted: Sat May 18, 2013 11:25 pm
by simplesi
Sucess :)
Moved camera to another RPi - different WiFI adaptor same SD card - same PSU - no flashing so at least the camera isn't k'nacked :)
raspivid -t 999999 -o - | nc 192.168.1.76 5001
c:\apps\nc\nc.exe -L -p 5001 | c:\apps\mplayer\mplayer.exe -fps 31 -cache 1024 -
Simon
Posted: Sun May 19, 2013 1:09 am
by RexRoper
My Pi reboots every time when I try this method. It has me quit baffled. :?: I am not certain what the cause is at this point, unless an update/upgrade has released since this past Wednesday evening.
Any suggestions?
Posted: Sun May 19, 2013 7:23 am
by recantha2
I sounds like that could be a power supply problem. Try a different one.
Posted: Sun May 19, 2013 8:07 am
by simplesi
Are you powering via microUSB - I put down many of my power type problems to doing this, then drawing largish currents, then the poly-fuse becomes more resistive, then everything shuts down or goes funny :(
If possible, try get 5V direct into you RPI - safest route is a powered hub into one of the USB ports.
There is a small risk IF your camera is faulty that you could do some damage to your RPi but assuming the camera is not faulty, then there is very little risk in trying this
Simon
Posted: Mon May 20, 2013 12:17 pm
by RexRoper
recantha2 wrote:I sounds like that could be a power supply problem. Try a different one.
Test voltage at TP1-TP2, I have 5.00VDC when my RPi is fully configured and powered. Voltage does not drop below 4V94 during boot process. I do not believe power to be the specific problem in this situation, but I could be mistaken.
Posted: Mon May 20, 2013 1:28 pm
by simplesi
I think James said it took quite a bit of current when recording a vid - so that would be the time to measure the volts i'd thought
Simon
