dhid
Video is mirror image
Wed May 15, 2013 4:27 pm
I've just connected up my newly arrived camera module and it is displaying video, both in the preview window and in recorded file, as mirror image. This applies to video and still images.
The display is otherwise normal.
Any ideas?
mikerr
Re: Video is mirror image
Wed May 15, 2013 4:32 pm
There's a Horizontal Flip option "-hf"
dhid
Wed May 15, 2013 4:47 pm
Thanks - yes I've just discovered and tried that option and it does fix it but if you don't use it the video always reverts to mirror image. I've tried powering off/on again but no joy.
Do they all do this?
dom
Wed May 15, 2013 5:31 pm
dhid wrote:Thanks - yes I've just discovered and tried that option and it does fix it but if you don't use it the video always reverts to mirror image. I've tried powering off/on again but no joy.
Yes. It's quite normal to flip the viewfinder on a front mounted camera (try it with the front camera of an iPhone) which is used for web chat type uses.
A rear mounted camera wouldn't normally be flipped.
Whether you think of this as being a front mounted camera or rear mounted camera is up to you.
dhid
Wed May 15, 2013 7:17 pm
Yes I understand the viewfinder point, but if I take a picture/video with my iPhone using either the front or rear camera it still records it to file the correct way round.
So is the Pi camera software supposed to record to file the correct way without using the -fh option?
I would have imagined the default would be to record not mirrored.
It's not a problem, I'm just curious.
EDIT typo: I meant -hf option of course.
Wed May 15, 2013 7:35 pm
On a SS (e.g. S2ve) phone the picture can be flipped when saving (it's an option), but by default its as if you are looking in a mirror which is technically flipped...
But I see you point about the default - I wonder if we ought to swap it. I'll have a chat with Dom in the morning.
dom
Wed May 15, 2013 8:07 pm
jamesh wrote:But I see you point about the default - I wonder if we ought to swap it. I'll have a chat with Dom in the morning.
Yes, I'd say flip the default.
May also want to allow separate flip of viewfinder compared to encoding for web chat type apps.
dhid
Wed May 15, 2013 8:11 pm
Thanks for your help guys.
By the way, I meant to say, I think you've done a good job with the camera, I'm impressed with the quality.
pluggy
Thu May 16, 2013 2:01 pm
Is it just me or is this behaviour bizarre ?
When I take a picture with a digital camera it should be the right way round as default. Whatever the camera does itself internally and this viewfinder front/back bit is irrelevent. The default should be to be correct. Get it changed now before it becomes a stupid standard.
I spent 5 minutes trying to fathom why my kitchen looked odd on the picture it took......
On a more positive note, the quality is excellent.
Thu May 16, 2013 2:08 pm
pluggy wrote:Is it just me or is this behaviour bizarre ?
"Get it changed now before it becomes a stupid standard"
I think you forgot "Please"
When you put a camera in a phone, it can either be on the front, on the back, the sensor itself can be mounted upside down (what ever that is), or even sideways. Even different models of the same phone can have the sensor mounted in different orientations. Then the customer may want it to be mirrored or not. And at least one customer we have wants the capture to be the other way round to the preview. It's not going to become a standard...
Allan
Thu May 16, 2013 2:11 pm
Can I throw in a vote for having the image flipped (or rather 'correct') by default please. The current behaviour is just weird.
pluggy
Thu May 16, 2013 2:26 pm
jamesh wrote: "Get it changed now before it becomes a stupid standard"
I'm sorry.
Please get it changed now before it becomes a stupid standard.
Its a raw camera module, its not in a phone. It should take pictures correctly when you point it at something. The "customer" can put -hf in the command line if he wants a mirror image. The rest of us want it the right way round. :)
piglet
Thu May 16, 2013 2:30 pm
+1 (but as a "pretty please with bells on" as and when you have time to get round to it :)).
RaTTuS
Contact: Twitter YouTube
Thu May 16, 2013 2:33 pm
+100
flip it horizonally - as the writing is the wrong way round... ;-p
/me trying to turn it into an IP camera
Covfefe
fbutler
Thu May 16, 2013 2:43 pm
+1 ( And I haven't even started playing with it yet :-))
pluggy
Thu May 16, 2013 2:44 pm
MarkDaniels
Thu May 16, 2013 2:56 pm
James, I, too, would definitely like to see the default setting swapped so that the camera is rear facing (i.e. output not mirrored). Perhaps you could arrange for a toggle in the software that we can set so that we can choose which is the default setting for the command line.
Thanks. Great little camera, BTW. Nice job overall.
pluggy
Thu May 16, 2013 3:09 pm
Maybe I should try it on a Pi that still has X on it.....
I have a script that strips X and a lot of the GUI stuff of a Raspdian Image for my headless Pis It makes a lot more room for stuff on the card, whilst keeping the best supported OS.
Thu May 16, 2013 3:56 pm
Well, you have the software source to do it in the app - quick job, but I think I'll try and sort it out in the firmware.
Allan
Thu May 16, 2013 4:42 pm
James, if you do the fix in firmware does that mean the preview will work? Currently, adding -hf to the command produces an image the right way round but the preview doesn't display, just a brief flash as the image is taken at the end of the preview period.
mikerr
Thu May 16, 2013 5:18 pm
The -e option will show the preview after compression - maybe that's also after flipping - not tried it though.
Thu May 16, 2013 6:29 pm
Allan wrote:James, if you do the fix in firmware does that mean the preview will work? Currently, adding -hf to the command produces an image the right way round but the preview doesn't display, just a brief flash as the image is taken at the end of the preview period.
Yes, I've noticed that but simply haven't had time to investigate it. Works fine in video mode, but not in capture which is a bit bizarre. I hope to have time to look at it tomorrow - I'm not allowed to take the source code home (except on my laptop, and I left it at work...).
Allan
Thu May 16, 2013 6:52 pm
Thanks James. I'm in no rush, there are plenty of other things to fiddle with.
Return to “Camera board”
