caij
Problem with video capture
Tue May 28, 2019 8:34 am
when I capture the video then I always get the video like that one? anyone knows what's the problem with camera? the light works 200hz
HermannSW
Re: Problem with video capture
Tue May 28, 2019 12:27 pm
Raspberry camera?
If so, v1 or v2?
What is the command [line] you use to capture the video?
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw
https://github.com/Hermann-SW/userland
https://twitter.com/HermannSW
caij
Tue May 28, 2019 1:19 pm
Hi HermannSW,
it's V2. the python code is
# -*- coding:utf-8-*-
import numpy
import cv2
cap=cv2.VideoCapture(0)
fourcc=cv2.cv.FOURCC(*'XVID')
out=cv2.VideoWriter('/home/pi/Documents/output.avi',fourcc,90,(640,480))
while(cap.isOpened()):
    ret,frame=cap.read()
    if ret==True:
        frame=cv2.flip(frame,0)
        out.write(frame)
        cv2.imshow('frame',frame)
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    else:
        break
cap.release()
out.release()
cv2.destroyAllWindows()
then use command:
$ sudo modprobe bem2835-v4l2
$ python2 VideoCapture.py
_______________________________________________________________
today I try just to capture a photo with decreased exposure time:
the photo is still with this black streak.
6by9
Tue May 28, 2019 2:05 pm
That looks like corruption from the sensor.
Please run
raspistill  -w 640 -h480 -ISO 100 -ss 1-out2.jpeg -r
and post the resulting file to somewhere like Dropbox and Google to share it. The file will be 8-11MB as it includes the raw data off the sensor. That enables us to analyse whether it is the sensor or the Pi at fault.
caij
Tue May 28, 2019 2:33 pm
so I have done this command
the result can be downloaded under this link
https://drive.google.com/file/d/1dbCI0F ... sp=sharing
6by9
Tue May 28, 2019 3:44 pm
So the corruption is on the data coming off the sensor. I'd put that down to either a faulty sensor, or interference on the CSI2 bus (the ribbon cable).
I do note that this is an OV5647 5MPix sensor. Raspberry Pi haven't sold that sensor since 2016, so I suspect that it is from some other supplier. Sorry, but you really need to raising this with them.
caij
Wed May 29, 2019 6:35 am
Thanks a lot 6by9! I did not know that it is actually a V1... Okey I am going to change this with V2. But by the way is there any codes that I can solve this date corruption on software?
caij
Fri May 31, 2019 11:46 am
when I turn down the light, that problem will disappear... Now I am being more confused... :?: :?: :?:
Return to “Camera board”
