JohnnyCyp
Wireless IP Camera to RPi
Sun May 05, 2019 11:05 am
Hello, i have a Wireless IP Camera (model CIPC-GC13H) and i want to connect it to my raspberry pi and make IT as a default camera for RPi. How can i do that ? The only way to control the camera is through to ios/android application but only link with mobile phones... The camera have also WiFi and Ethernet port and supported face recognition, motion detection and night vision. I have found the IP and MAC address of the camera but then what i have to with that ?
https://www.youtube.com/watch?v=LshlQJCPAt8
topguy
Re: Wireless IP Camera to RPi
Sun May 05, 2019 2:47 pm
JohnnyCyp
Mon May 06, 2019 10:08 am
Some info at the end here:
https://ipcamtalk.com/threads/meisort-y203s.24661/
Thanks, works with RTSP... but how can i make it to working as Pi Camera ?
topguy
Mon May 06, 2019 10:13 am
Most likely you cant.
But what do you really mean by this ? Do you expect to use "raspistill" and "raspivid" ? What do you want to use the camera for ?
B.Goode
Mon May 06, 2019 10:17 am
If you mean you want use use it with the 'bundled' camera applications such as raspistill documented here: https://www.raspberrypi.org/documentati ... /camera.md, or with the Python picamera module https://picamera.readthedocs.io/en/release-1.13/, then I don't think you can use a third-party camera in that way. My understanding is that they are dedicated to the official Raspberry Pi Foundation camera module: https://www.raspberrypi.org/products/camera-module-v2/
Edit: similar to the clarification sought as I was researching this....
topguy
Mon May 06, 2019 2:10 pm
This thread hints that it might be possible to make it work with V4L2 applications, but its an old thread.
https://unix.stackexchange.com/question ... ter-device
JohnnyCyp
Tue May 07, 2019 7:43 am
I don't want to use the camera for raspistill and raspivid commands... I want to use it for a project i'm working on which i will use the camera to capture photograph when a PIR sensor detected a motion...
JohnnyCyp
Tue May 07, 2019 9:13 am
I'm thinking if i can use this code: gst-launch-1.0 -v rtspsrc location=rtsp://your_stream_url ! v4l2sink device=/dev/video1 from the old thread for V4L2 applications with fswebcam: https://www.raspberrypi.org/documentati ... e/webcams/ to control the third party camera and take pictures manually with command: fswebcam -r 640x480 -d /dev/video0 testpicture.jpg
Return to “Camera board”
