PI Zero W Crash with V2 Kamera Modul with Motion/BCM2835
Posted: Tue Jan 08, 2019 3:32 pm
by leon2k6
Hey together,
I would like to use the RaPi as a (Live) Webcam, so I have installed the newest Raspbian Lite and the software Motion 4.2.1 and also Motioneye. Everything worked fine, but after some seconds in the webinterface, I get a crash like this:
Jan 8 15:09:14 raspberrypi motion: [0:motion] [NTC] [ALL] motion_startup: Motion 4.2.1 Started
Jan 8 15:09:14 raspberrypi motion: [0:motion] [NTC] [ALL] motion_startup: Using default log type (ALL)
Jan 8 15:09:14 raspberrypi motion: [0:motion] [NTC] [ALL] motion_startup: Using log type (ALL) log level (WRN)
Jan 8 15:09:21 raspberrypi kernel: [ 42.461450] Modules linked in: bnep hci_uart btbcm serdev bluetooth ecdh_generic brcmfmac brcmutil cfg80211 snd_bcm2835(C) rfkill snd_pcm snd_timer snd fixed uio_pdrv_genirq uio bcm2835_v4l2(C) v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core videodev media ip_tables x_tables ipv6
Jan 8 15:09:21 raspberrypi kernel: [ 42.474116] CPU: 0 PID: 156 Comm: kworker/0:4 Tainted: G C 4.14.79+ #1159
Jan 8 15:09:21 raspberrypi kernel: [ 42.481330] Hardware name: BCM2835
Jan 8 15:09:21 raspberrypi kernel: [ 42.487475] Workqueue: mm_percpu_wq drain_local_pages_wq
Jan 8 15:09:21 raspberrypi kernel: [ 42.493669] task: d55a1bc0 task.stack: d5614000
Jan 8 15:09:21 raspberrypi kernel: [ 42.500272] PC is at free_pcppages_bulk+0x274/0x498
Jan 8 15:09:21 raspberrypi kernel: [ 42.506883] LR is at 0xd7e4a41c
Jan 8 15:09:21 raspberrypi kernel: [ 42.514169] pc : [<c00fb8ec>] lr : [<d7e4a41c>] psr: 60000193
Jan 8 15:09:21 raspberrypi kernel: [ 42.520769] sp : d5615e78 ip : d7e4a408 fp : d5615ec4
Jan 8 15:09:21 raspberrypi kernel: [ 42.527199] r10: 00000001 r9 : d7e4a408 r8 : 00000001
Jan 8 15:09:21 raspberrypi kernel: [ 42.533852] r7 : ffffffff r6 : 0000c730 r5 : c09c6684 r4 : c09c6650
Jan 8 15:09:21 raspberrypi kernel: [ 42.540398] r3 : 00000034 r2 : c09c6650 r1 : 00000001 r0 : c09c66cc
Jan 8 15:09:21 raspberrypi kernel: [ 42.547611] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Jan 8 15:09:21 raspberrypi kernel: [ 42.553956] Control: 00c5387d Table: 155d8008 DAC: 00000055
Jan 8 15:09:21 raspberrypi kernel: [ 42.666619] [<c00fb8ec>] (free_pcppages_bulk) from [<c00fbb90>] (drain_pages_zone+0x80/0x8c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.673813] [<c00fbb90>] (drain_pages_zone) from [<c00fc0c4>] (drain_pages+0x50/0x64)
Jan 8 15:09:21 raspberrypi kernel: [ 42.681729] [<c00fc0c4>] (drain_pages) from [<c00fc858>] (drain_local_pages_wq+0x1c/0x20)
Jan 8 15:09:21 raspberrypi kernel: [ 42.688675] [<c00fc858>] (drain_local_pages_wq) from [<c0039364>] (process_one_work+0x11c/0x398)
Jan 8 15:09:21 raspberrypi kernel: [ 42.696247] [<c0039364>] (process_one_work) from [<c00397c8>] (worker_thread+0x1e8/0x544)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702298] Modules linked in: bnep hci_uart btbcm serdev bluetooth ecdh_generic brcmfmac brcmutil cfg80211 snd_bcm2835(C) rfkill snd_pcm snd_timer snd fixed uio_pdrv_genirq uio bcm2835_v4l2(C) v4l2_common videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core videodev media ip_tables x_tables ipv6
Jan 8 15:09:21 raspberrypi kernel: [ 42.702341] CPU: 0 PID: 156 Comm: kworker/0:4 Tainted: G C 4.14.79+ #1159
Jan 8 15:09:21 raspberrypi kernel: [ 42.702343] Hardware name: BCM2835
Jan 8 15:09:21 raspberrypi kernel: [ 42.702346] Workqueue: mm_percpu_wq drain_local_pages_wq
Jan 8 15:09:21 raspberrypi kernel: [ 42.702350] task: d55a1bc0 task.stack: d5614000
Jan 8 15:09:21 raspberrypi kernel: [ 42.702352] PC is at cfb_imageblit+0x42c/0x980
Jan 8 15:09:21 raspberrypi kernel: [ 42.702354] LR is at 0xda800000
Jan 8 15:09:21 raspberrypi kernel: [ 42.702358] pc : [<c03a80d0>] lr : [<da800000>] psr: 20000193
Jan 8 15:09:21 raspberrypi kernel: [ 42.702360] sp : d56158d0 ip : 00000000 fp : d5615924
Jan 8 15:09:21 raspberrypi kernel: [ 42.702363] r10: 00000010 r9 : 00000001 r8 : 00000000
Jan 8 15:09:21 raspberrypi kernel: [ 42.702366] r7 : 00000020 r6 : 00000020 r5 : ff000000 r4 : ffaaaaaa
Jan 8 15:09:21 raspberrypi kernel: [ 42.702369] r3 : e1d90040 r2 : d703fb70 r1 : 00001c80 r0 : d7290800
Jan 8 15:09:21 raspberrypi kernel: [ 42.702373] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Jan 8 15:09:21 raspberrypi kernel: [ 42.702376] Control: 00c5387d Table: 155d8008 DAC: 00000055
Jan 8 15:09:21 raspberrypi kernel: [ 42.702614] [<c03a80d0>] (cfb_imageblit) from [<c03a8ad8>] (bcm2708_fb_imageblit+0x18/0x1c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702618] [<c03a8ad8>] (bcm2708_fb_imageblit) from [<c03a6730>] (bit_putcs+0x254/0x400)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702621] [<c03a6730>] (bit_putcs) from [<c03a02f0>] (fbcon_putcs+0xf4/0x12c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702625] [<c03a02f0>] (fbcon_putcs) from [<c03a26cc>] (fbcon_redraw+0x164/0x1c4)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702628] [<c03a26cc>] (fbcon_redraw) from [<c03a50ec>] (fbcon_scroll+0x27c/0xdd0)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702632] [<c03a50ec>] (fbcon_scroll) from [<c03dab10>] (con_scroll+0xf0/0xfc)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702635] [<c03dab10>] (con_scroll) from [<c03dabb0>] (lf+0x94/0x9c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702638] [<c03dabb0>] (lf) from [<c03db73c>] (vt_console_print+0x254/0x370)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702642] [<c03db73c>] (vt_console_print) from [<c005f954>] (console_unlock+0x234/0x45c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702646] [<c005f954>] (console_unlock) from [<c005fcd0>] (vprintk_emit+0x154/0x244)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702649] [<c005fcd0>] (vprintk_emit) from [<c005ff88>] (vprintk_default+0x4c/0x7c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702653] [<c005ff88>] (vprintk_default) from [<c0061270>] (vprintk_func+0x50/0xb8)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702656] [<c0061270>] (vprintk_func) from [<c0060c0c>] (printk+0x30/0x38)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702660] [<c0060c0c>] (printk) from [<c0013bfc>] (dump_backtrace_entry+0x38/0xa4)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702664] [<c0013bfc>] (dump_backtrace_entry) from [<c00164a4>] (unwind_backtrace+0x84/0x104)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702667] [<c00164a4>] (unwind_backtrace) from [<c0013f54>] (die+0x210/0x294)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702672] [<c0013f54>] (die) from [<c0018f90>] (__do_kernel_fault.part.0+0x64/0x84)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702677] [<c0018f90>] (__do_kernel_fault.part.0) from [<c064f3c0>] (do_page_fault+0x23c/0x3b8)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702680] [<c064f3c0>] (do_page_fault) from [<c0009200>] (do_DataAbort+0x44/0xc4)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702685] [<c0009200>] (do_DataAbort) from [<c064eab4>] (__dabt_svc+0x54/0x80)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702688] Exception stack(0xd5615e28 to 0xd5615e70)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702692] 5e20: c09c66cc 00000001 c09c6650 00000034 c09c6650 c09c6684
Jan 8 15:09:21 raspberrypi kernel: [ 42.702696] 5e40: 0000c730 ffffffff 00000001 d7e4a408 00000001 d5615ec4 d7e4a408 d5615e78
Jan 8 15:09:21 raspberrypi kernel: [ 42.702700] 5e60: d7e4a41c c00fb8ec 60000193 ffffffff
Jan 8 15:09:21 raspberrypi kernel: [ 42.702704] [<c064eab4>] (__dabt_svc) from [<c00fb8ec>] (free_pcppages_bulk+0x274/0x498)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702708] [<c00fb8ec>] (free_pcppages_bulk) from [<c00fbb90>] (drain_pages_zone+0x80/0x8c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702711] [<c00fbb90>] (drain_pages_zone) from [<c00fc0c4>] (drain_pages+0x50/0x64)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702717] [<c00fc0c4>] (drain_pages) from [<c00fc858>] (drain_local_pages_wq+0x1c/0x20)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702721] [<c00fc858>] (drain_local_pages_wq) from [<c0039364>] (process_one_work+0x11c/0x398)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702725] [<c0039364>] (process_one_work) from [<c00397c8>] (worker_thread+0x1e8/0x544)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702729] [<c00397c8>] (worker_thread) from [<c003f518>] (kthread+0x120/0x15c)
Jan 8 15:09:21 raspberrypi kernel: [ 42.702733] [<c003f518>] (kthread) from [<c000fe2c>] (ret_from_fork+0x14/0x2
Jan 8 15:09:21 raspberrypi kernel: [ 42.702740] Lost 2 message(s)!
Jan 8 15:12:23 raspberrypi motion: [1:ml1] [WRN] [ALL] motion_init: Could not fetch initial image from camera
Jan 8 15:12:24 raspberrypi motion: [1:ml1] [WRN] [ALL] motion_init: Motion continues using width and height from config file(s)Jan 8 15:09:14 raspberrypi motion: [0:motion] [NTC] [ALL] motion_startup: Motion 4.2.1 Started
What I have done so far: dist-ugrade, rpi-update, tried 3 AC and 4 different USB cable.
IMHO I think when I am using the PI without the camera modul on the CSi interface, I have no crash after one hour...
I dont know why it crash, when the camera is attached :/, any ideas or log files where I can see some further logs?
Re: PI Zero W Crash with V2 Kamera Modul with Motion/BCM2835
Posted: Mon May 13, 2019 7:13 am
by lpsw
I'm just now seeing something similar.
Some config info, from crash time:
  • Raspberry Pi Zero W Rev 1.1
    temp=59.5'C
    volt=1.3500V
    throttled=0x0
    Linux pi-10 4.14.98+ #1200 Tue Feb 12 20:11:02 GMT 2019 armv6l GNU/Linux
    uptime: 01:30:01 up 3:12, 1 user, load average: 0.21, 0.29, 0.28
I currently run 5 Pi0Ws, all headless, and all streaming Pikrellcam, with identical SD card images (except of course hostname). Only devices attached are an official non-NoIR camera and an external wifi adapter (the built in WiFi doesn't have the range needed). All are in Zeroview cases from Pi Hut. Some have been running almost continuously for over a year. Only outages were for updates. Never a crash.
Recently I got a new Pi0W and new NoIR camera, using the same image as the other Pi0Ws.
Differences:
  • NoIR camera
    Using the internal wifi chip, for testing.
    Not yet in a Zeroview case.
    New zero running +9/10C above the other 5 Pi0Ws (due to internal vs external wifi (?)).
Streaming was working fine on the new Pi, images looked good via browser. I SSH'd in, tailing syslog, looking for the previously reported bug. Video still looked good in the browser. I started another SSH session via Putty (duplicated the first session), which failed with a strange message from putty indicating a key mismatch. Can't be true, since I could restart the session successfully, so the key is fine. Immediately, the Pikrellcam video stream stopped. After reboot, putty repeatedly complained about connection refused. Had to power cycle (we used to call that a poughkeepsie reset LOL).
From syslog. The paging request failure (first line) is interesting (page crosser?). Also @ 11610.698610: Internal error: Oops - undefined instruction: 0 [#3] ARM
[11609.157926] Unable to handle kernel paging request at virtual address fffffff8
[11609.162982] pgd = d4ad8000
[11609.165511] [fffffff8] *pgd=17ffa861, *pte=00000000, *ppte=00000000
[11609.170027] Internal error: Oops: 37 [#1] ARM
[11609.178388] Unable to handle kernel paging request at virtual address d9cd0014
[11609.178394] pgd = d4ad8000
[11609.178397] [d9cd0014] *pgd=00000000
[11609.178403] Internal error: Oops: 805 [#2] ARM
[11609.178405] Modules linked in: bnep hci_uart btbcm serdev bluetooth ecdh_generic spidev brcmfmac brcmutil snd_bcm2835(C) snd_pcm cfg80211 snd_timer snd rfkill i2c_bcm2835 spi_bcm2835 fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[11609.178443] CPU: 0 PID: 2275 Comm: ps Tainted: G         C      4.14.98+ #1200
[11609.178445] Hardware name: BCM2835
[11609.178448] task: d68f6120 task.stack: d3b60000
[11609.178450] PC is at cfb_imageblit+0x6a8/0x980
[11609.178452] LR is at 0xd703f2f0
[11609.178456] pc : [<c03ab55c>]    lr : [<d703f2f0>]    psr: 20000193
[11609.178458] sp : d3b618f8  ip : 00000000  fp : d3b6194c
[11609.178462] r10: d9cd0014  r9 : d703f2f0  r8 : d703f2f9
[11609.178465] r7 : 0000000f  r6 : 00000050  r5 : ff000000  r4 : 00aaaaaa
[11609.178468] r3 : 00000000  r2 : d9cd0014  r1 : c0689ce8  r0 : ff000000
[11609.178472] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[11609.178475] Control: 00c5387d  Table: 14ad8008  DAC: 00000055
[11609.178478] Process ps (pid: 2275, stack limit = 0xd3b60188)
[11609.178480] Stack: (0xd3b618f8 to 0xd3b62000)
[11609.178484] 18e0:                                                       00000001 20000193
[11609.178489] 1900: 00000001 00000009 00000a40 00000000 0000000a 00000140 0000000a d9cd0014
[11609.178493] 1920: c094e5c0 00000000 d703f2fa d72a0890 00000000 d7028400 00000001 000000ff
[11609.178497] 1940: d3b6195c d3b61950 c03abce8 c03aaec0 d3b61a24 d3b61960 c03a9940 c03abcdc
[11609.178501] 1960: 00000001 00000020 00000001 d9100a00 00000000 d7028508 ffffffff d72909a4
[11609.178505] 1980: ffffffff 00000000 00000200 00000000 00000000 d7290800 d72a087c 0000000a
[11609.178509] 19a0: 0000000a d3b619b0 c03a9c68 c03abcdc 00000000 00000000 00000010 00000001
[11609.178513] 19c0: 000000a0 000000c0 00000050 00000010 00000007 00000000 c0684b01 d703f2f0
[11609.178517] 19e0: d3b61a74 d3b619f0 c03a96b8 c03a9af8 d3b61ae4 c03a31dc d3b61a24 d7290800
[11609.178522] 1a00: d7028400 0000000c d72a087c 0000000a c03a96ec 00000007 d3b61a64 d3b61a28
[11609.178526] 1a20: c03a3500 c03a96f8 0000000c 00000014 00000007 00000000 00000000 d72a0892
[11609.178530] 1a40: 00000720 0000000b d72a07ec 00000700 00000014 d72a087c d3b61aac d3b61a68
[11609.178534] 1a60: c03a58dc c03a3418 00000014 d3b61a78 0000000d d7028400 0000000c d72a08f8
[11609.178539] 1a80: ffffffff d7028400 00000001 00000000 c0a589c8 c09459e8 00000019 00000005
[11609.178543] 1aa0: d3b61b14 d3b61ab0 c03a82fc c03a5784 00000052 00000000 00000000 00000000
[11609.178548] 1ac0: 00000010 0000001a 00000005 d7290800 00000000 c0a5a9c0 d7028400 00000000
[11609.178552] 1ae0: 00000001 c0a58a10 00000509 0000001a 00000001 d7028400 00000005 00000000
[11609.178557] 1b00: 00000000 00000001 d3b61b44 d3b61b18 c03dded8 c03a808c 00000001 00000007
[11609.178561] 1b20: d3b61b6c d7028400 00000030 0000000a 00000030 c09fe521 d3b61b6c d3b61b48
[11609.178565] 1b40: c03ddf78 c03dddf4 00000001 0000000a 00000030 c09fe521 00000000 d7028400
[11609.178569] 1b60: d3b61bb4 d3b61b70 c03deb04 c03ddef0 00000000 0000000f d72a1004 c09fe521
[11609.178573] 1b80: d7028400 0000004d 00004430 c09a1738 00000000 00000031 00004478 00000000
[11609.178577] 1ba0: c09ffb60 c09ddbe8 d3b61c14 d3b61bb8 c005f9a8 c03de8bc d3b61be4 d3b61bc8
[11609.178581] 1bc0: c0059ea8 00000000 c005fdc4 00000001 60000193 00000000 000000ec 0000000f
[11609.178585] 1be0: 000000ed 00000000 00000021 00000021 00000000 00000000 00000000 c0949c38
[11609.178589] 1c00: 60000193 d68f6120 d3b61c64 d3b61c18 c005fdc4 c005f76c c079e2a4 d3b61cbc
[11609.178593] 1c20: d3b61c7c d3b61c30 c005fdc4 c005f76c 00000000 d3b61cd4 60000113 c09dafa4
[11609.178598] 1c40: 60000113 d3b61e20 c079f07c c0949c38 00000037 d68f6120 d3b61c7c d3b61c68
[11609.178601] 1c60: c006018c c005fc78 c079e2a4 d3b61cbc d3b61c9c d3b61c80 c0061470 c006014c
[11609.178606] 1c80: c0014108 c00fb0ec d3b61cb4 c09dafa4 d3b61cb4 d3b61ca0 c0060e0c c006142c
[11609.178610] 1ca0: c09570a0 d3b61cbc d3b61cfc d3b61cc8 c0013de8 c0060dec c079e2a4 c079f07c
[11609.178614] 1cc0: 00000037 00000001 c0018e18 c0060dec c079f014 fffffff8 00000037 d3b61e20
[11609.178618] 1ce0: d7008820 d7008820 d7008858 00000014 d3b61d14 d3b61d00 c0018f90 c0013d50
[11609.178623] 1d00: d3b61e20 fffffff8 d3b61d6c d3b61d18 c0653580 c0018f38 0000a206 c0127ba0
[11609.178627] 1d20: d6b82a20 c0127b88 d6b82a20 0000a206 d3b61d8c 00000000 00000000 00010000
[11609.178631] 1d40: 00000000 c0949f7c 00000037 c0653344 fffffff8 d3b61e20 d3b60000 beba8f05
[11609.178635] 1d60: d3b61e1c d3b61d70 c0009200 c0653350 d3b61e9f 00000000 d39f6b60 00000000
[11609.178639] 1d80: d3b61de4 d3b61d90 c01280fc c01277c8 0000a006 d3b61e1c d3b61e18 00000000
[11609.178643] 1da0: d4147928 0000a806 d39f6b98 0000a006 00000000 00000000 c0662970 beba8f22
[11609.178647] 1dc0: beba8f22 00000001 d3b61e9f 00000000 c0947c00 60000013 60000013 d7c72aec
[11609.178651] 1de0: c09caaf0 c09caaf0 d3b61e34 d3b61df8 c00fdb9c c00c5e24 c09cb098 c01c336c
[11609.178655] 1e00: 20000013 ffffffff d3b61e54 beba8f23 d3b61edc d3b61e20 c0652c74 c00091c8
[11609.178659] 1e20: 00000000 d7f50c04 00000000 d39f6b88 d39f6b60 00000000 d3b61f80 0001ffe2
[11609.178663] 1e40: beba8f23 b6b05026 beba8f05 d3b61edc d3b61e58 d3b61e70 c001f3c0 c01c336c
[11609.178667] 1e60: 20000013 ffffffff c01c336c bf000000 00008000 d3b51c00 d3b61edc 00000006
[11609.178671] 1e80: d3b61f5c d3b61ea8 0000001e beba8fde beba8f23 d4b5b000 d3b61f4c 00b61ea8
[11609.178675] 1ea0: c016b0bc c01649a0 d68b5010 d41edcc0 f78cee69 d4b5aaa0 d3b61f80 b6b05026
[11609.178679] 1ec0: d3b61f80 0001ffe2 d3b60000 00000000 d3b61f4c d3b61ee0 c015b2b4 c01c32e0
[11609.178684] 1ee0: 00000000 d3b61ee8 00020000 c015b4e0 d70c8d80 00000001 d4b5aaa8 d3b61f08
[11609.178688] 1f00: c0178e5c c064eac8 c0178c88 00000000 00000000 00020000 d3a3c000 c015b420
[11609.178692] 1f20: d3a3c000 0000001e 0001ffe2 d4b5aaa0 b6b05026 d3b61f80 c000ff24 d3b60000
[11609.178696] 1f40: d3b61f7c d3b61f50 c015b444 c015b288 00000000 c01790dc d3b61f7c d4b5aaa0
[11609.178700] 1f60: d4b5aaa0 0001ffe2 b6b05026 c000ff24 d3b61fa4 d3b61f80 c015b9f8 c015b3b8
[11609.178704] 1f80: 0000001e 00000000 0000001e b6b05008 b6b05026 00000003 00000000 d3b61fa8
[11609.178709] 1fa0: c000fd80 c015b9b0 0000001e b6b05008 00000006 b6b05026 0001ffe2 00000006
[11609.178713] 1fc0: 0000001e b6b05008 b6b05026 00000003 00033d50 00020000 0001ffe2 00000006
[11609.178716] 1fe0: 00000000 be96a3f4 b6f79d94 b6ee453c 60000010 00000006 00000000 00000000
[11609.178720] [<c03ab55c>] (cfb_imageblit) from [<c03abce8>] (bcm2708_fb_imageblit+0x18/0x1c)
[11609.178725] [<c03abce8>] (bcm2708_fb_imageblit) from [<c03a9940>] (bit_putcs+0x254/0x400)
[11609.178728] [<c03a9940>] (bit_putcs) from [<c03a3500>] (fbcon_putcs+0xf4/0x12c)
[11609.178732] [<c03a3500>] (fbcon_putcs) from [<c03a58dc>] (fbcon_redraw+0x164/0x1c4)
[11609.178736] [<c03a58dc>] (fbcon_redraw) from [<c03a82fc>] (fbcon_scroll+0x27c/0xdd0)
[11609.178739] [<c03a82fc>] (fbcon_scroll) from [<c03dded8>] (con_scroll+0xf0/0xfc)
[11609.178742] [<c03dded8>] (con_scroll) from [<c03ddf78>] (lf+0x94/0x9c)
[11609.178746] [<c03ddf78>] (lf) from [<c03deb04>] (vt_console_print+0x254/0x370)
[11609.178751] [<c03deb04>] (vt_console_print) from [<c005f9a8>] (console_unlock+0x248/0x50c)
[11609.178755] [<c005f9a8>] (console_unlock) from [<c005fdc4>] (vprintk_emit+0x158/0x358)
[11609.178759] [<c005fdc4>] (vprintk_emit) from [<c006018c>] (vprintk_default+0x4c/0x7c)
[11609.178762] [<c006018c>] (vprintk_default) from [<c0061470>] (vprintk_func+0x50/0xb8)
[11609.178766] [<c0061470>] (vprintk_func) from [<c0060e0c>] (printk+0x30/0x38)
[11609.178769] [<c0060e0c>] (printk) from [<c0013de8>] (die+0xa4/0x294)
[11609.178773] [<c0013de8>] (die) from [<c0018f90>] (__do_kernel_fault.part.0+0x64/0x84)
[11609.178777] [<c0018f90>] (__do_kernel_fault.part.0) from [<c0653580>] (do_page_fault+0x23c/0x3b8)
[11609.178781] [<c0653580>] (do_page_fault) from [<c0009200>] (do_DataAbort+0x44/0xc4)
[11609.178784] [<c0009200>] (do_DataAbort) from [<c0652c74>] (__dabt_svc+0x54/0x80)
[11609.178787] Exception stack(0xd3b61e20 to 0xd3b61e68)
[11609.178791] 1e20: 00000000 d7f50c04 00000000 d39f6b88 d39f6b60 00000000 d3b61f80 0001ffe2
[11609.178795] 1e40: beba8f23 b6b05026 beba8f05 d3b61edc d3b61e58 d3b61e70 c001f3c0 c01c336c
[11609.178798] 1e60: 20000013 ffffffff
[11609.178801] [<c0652c74>] (__dabt_svc) from [<c01c336c>] (proc_pid_cmdline_read+0x98/0x4dc)
[11609.178806] [<c01c336c>] (proc_pid_cmdline_read) from [<c015b2b4>] (__vfs_read+0x38/0x130)
[11609.178810] [<c015b2b4>] (__vfs_read) from [<c015b444>] (vfs_read+0x98/0x168)
[11609.178813] [<c015b444>] (vfs_read) from [<c015b9f8>] (SyS_read+0x54/0xb0)
[11609.178817] [<c015b9f8>] (SyS_read) from [<c000fd80>] (ret_fast_syscall+0x0/0x28)
[11609.178820] Code: e0810100 e5900050 e0000004 e0200005 (e5820000)
[11609.178823] ---[ end trace 78d966f7b51d1696 ]---
[11610.698610] Internal error: Oops - undefined instruction: 0 [#3] ARM
[11610.698616] Modules linked in: bnep hci_uart btbcm serdev bluetooth ecdh_generic spidev brcmfmac brcmutil snd_bcm2835(C) snd_pcm cfg80211 snd_timer snd rfkill i2c_bcm2835 spi_bcm2835 fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[11610.698660] CPU: 0 PID: 37 Comm: vchiq-slot/0 Tainted: G      D  C      4.14.98+ #1200
[11610.698664] Hardware name: BCM2835
[11610.698667] task: d721ef00 task.stack: d684e000
[11610.698670] PC is at num_spec.56977+0x45c0c/0x160d00
[11610.698672] LR is at up+0x4c/0x8c
[11610.698676] pc : [<c06ee044>]    lr : [<c005a144>]    psr: 80000013
[11610.698679] sp : d684fef0  ip : d684fe90  fp : d684ff7c
[11610.698682] r10: c0a61120  r9 : c09c05e4  r8 : d38e2000
[11610.698686] r7 : 00000010  r6 : d7580194  r5 : d38e20dc  r4 : 00000000
[11610.698690] r3 : 000007d4  r2 : 000df302  r1 : b5f06570  r0 : 00000000
[11610.698694] Flags: Nzcv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[11610.698697] Control: 00c5387d  Table: 13b48008  DAC: 00000055
[11610.698701] Process vchiq-slot/0 (pid: 37, stack limit = 0xd684e188)
[11610.698704] Stack: (0xd684fef0 to 0xd6850000)
[11610.698708] fee0:                                     d70e8000 c094e590 00000000 c0966200
[11610.698712] ff00: d684ff64 d684ff10 c064e454 c0046c7c c0a611f0 d38e2110 c0a611a8 c0a61144
[11610.698716] ff20: d7580194 c0a6142c d7580020 d38e2188 14034780 00000009 00000056 d7580194
[11610.698721] ff40: fff9fee9 ffffffff 00000000 00000000 d7301bd8 d7301bc0 00000000 d6850680
[11610.698725] ff60: c0a61120 c0518fa0 d7301bd8 d70e3c9c d684ffac d684ff80 c003f568 c0518fac
[11610.698730] ff80: ffffffff d6850680 c003f448 00000000 00000000 00000000 00000000 00000000
[11610.698734] ffa0: 00000000 d684ffb0 c000fe2c c003f454 00000000 00000000 00000000 00000000
[11610.698738] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[11610.698742] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[11610.698746] [<c005a144>] (up) from [<c003f568>] (kthread+0x120/0x15c)
[11610.698750] [<c003f568>] (kthread) from [<c000fe2c>] (ret_from_fork+0x14/0x28)
[11610.698754] Code: 69fbfa08 cef5ffee 72540f74 669bb5f6 (ee699566)
[11610.698757] ---[ end trace 78d966f7b51d1697 ]---
Sorry for the TL;DR
Edit 1: Added: All Pis are using official 5V1/2A5 RPi branded power supplies.
Edit 2: Format/clarity
Posted: Thu May 16, 2019 7:01 pm
by lpsw
After looking at
https://www.raspberrypi.org/forums/view ... 3&t=212777
I tried over_voltage=8 (1.4V), and new zero is streaming fine now for >24 hours. Max before was less than 2 hours.
May be too early to tell, but looks like it is having a positive effect.
Pi is still running +9C above by other zeros, all streaming fine at 1.2V.
New one runs hotter and needs a voltage boost. I can live with that, but still interesting.
BTW, the increased voltage does not appear to increase CPU temp.
