procras
System lock up on interruption of python camera code
Wed Oct 31, 2018 7:57 pm
I have written this small python code to tell my camera to capture images of the night sky.
#!/usr/bin/python3
from picamera import PiCamera
from time import sleep
from fractions import Fraction
from shutil import copyfile
import datetime as dt
camera = PiCamera(
        resolution=(1280,720),
        #resolution=(2592,1944),
        framerate=Fraction(1,6),
        sensor_mode=3)
camera.rotation = 180
camera.shutter_speed = 6000000
camera.iso = 800
sleep(30)
camera.exposure_mode = 'off'
x = 1
while (1):
    string = dt.datetime.now().strftime('%Y-%m-%d_%H_%M_%S')
    fullstring = '/home/pi/nightlapse/images/image_%s.jpg' % string
    print('Starting capture ...')
    camera.capture(fullstring)
    print('Captured image %s' %fullstring)
    copyfile(fullstring, '/home/pi/nightlapse/webapp/static/image.jpg')
    sleep(60)
    x +=1
The images are taken, I see the image file being created in the filesystem about 20 seconds before the program
prints out Captured image .....
My problem is when I want to stop the program.
I use ^C and the program usually interrupts (not always!).
Often the system then becomes unresponsive and cannot be shutdown or connected to remotely.
All I can do at that stage is pull the power (which is abhorrant).
Is this the expected behaviour with the camera and PiCamera?
Have I made a mistake in my code.
I had no lockups before using a cron job to call a bash script that called raspistill every 5 minutes, but
was hoping to get more images as my exposure is 6 seconds.
Thanks.
Return to “Camera board”
