I'm trying to perform live processing on a video stream using mode=1 (documented as being 1920x1080 pixels from the middle of the sensor) on a camera V2.1. I'm starting with the code
#!/usr/bin/env python3
import time
import picamera
class FrameHandler(object):
def write(self, buf):
pass
def flush(self):
pass
with picamera.PiCamera(sensor_mode=1, resolution='1920x1080', framerate=30) as camera:
time.sleep(2) # let the camera warm up
camera.start_recording(FrameHandler(), 'yuv')
camera.wait_recording(10)
camera.stop_recording()
When I run this code, I get the warning message
Which sounds as if it will cause the image to be rescaled slightly before it's passed to my frame handler, which I don't want to happen./usr/lib/python3/dist-packages/picamera/encoders.py:544: PiCameraResolutionRounded: frame size rounded up from 1920x1080 to 1920x1088
width, height, fwidth, fheight)))
How can I get un-scaled mode 1 data?
Thanks for any hints!
John
