puppy101puppy
De-cap Camera v2 / Remove Lenses
Sat May 21, 2016 2:33 am
Does anyone have tried to remove lenses on the new camera module v2 (in order to change lenses or work with other geometry)? I suppose it's still glued as the v1 omnivision camera. Any suggestions on which edge/corner will be safer to cut? (Appreciated if there's a photo of decapping process or sensor with lens removed)
Thanks!!!
rpdom
Re: De-cap Camera v2 / Remove Lenses
Sat May 21, 2016 4:08 am
puppy101puppy wrote:Does anyone have tried to remove lenses on the new camera module v2
Yes. Quite a few people have changed the lens or adjusted the focus.
To do this you need to carefully remove the small blobs of glue that hold the lens in place, then the lens should turn.
You can do this with pliers, but some have found that they sometimes slip and scratch the lens. Some people have made specialist lens "spanners" as mentioned in the Camera Q&A thread viewtopic.php?f=43&t=145815&start=225#p973062
jbeale
Sat May 21, 2016 4:19 am
I think I may be the only person to have destroyed my lens with pliers (but, I wiped out two of them). Using the right tool it's quite easy, and I think safe. You don't need to remove the glue at all. Just a slight twist of the tool, and the glue gives way with a little snap sound. From there it is relatively easy to adjust with fingernails.
The newer version of the lens adjustment tool is here: http://www.thingiverse.com/thing:1574661
puppy101puppy
Sat May 21, 2016 7:11 am
jbeale wrote:I think I may be the only person to have destroyed my lens with pliers (but, I wiped out two of them). Using the right tool it's quite easy, and I think safe. You don't need to remove the glue at all. Just a slight twist of the tool, and the glue gives way with a little snap sound. From there it is relatively easy to adjust with fingernails.
Hi Jbeale,
That looks interesting, though I'm looking to remove the lens (not adjust the focus).
However, the holder still looks sort of useful -- will print it and try tomorrow.
Do you happened to have a picture of the decapped Sony IMX219 (sensor without lens)? If yes, could you share it with me (would be great to see which edge has no electronics so it's safe to cut from that edge).
Thank you!
gordon77
Sat May 21, 2016 7:18 am
Why do you want to cut it? Why not just unscrew the lens? You can fit a 12mm adaptor using the mounting holes.
puppy101puppy
Sat May 21, 2016 7:25 am
Hi rpdom,
Thanks for the link. Do you happened to have seen a picture of the decapped Sony IMX219 (sensor without lens)? If yes, could you share it with me? (would be great to see which edge has no electronics so it's safer to cut from that edge).
Thanks.
puppy101puppy
Sat May 21, 2016 7:27 am
gordon77 wrote:Why do you want to cut it? Why not just unscrew the lens? You can fit a 12mm adaptor using the mounting holes.
Targeting some contact imaging.
gordon77
Sat May 21, 2016 10:19 am
v2.1 without lens if that helps...
v2.1
imadaily
Sun May 22, 2016 5:34 pm
Some more images, looking at different angles into the lens holder with the lens removed.
http://imgur.com/a/4Sr5W
k_sze
Sat Jun 25, 2016 12:55 am
One thing I don't understand is *why* they bother gluing the lens at all. Can somebody petition Raspberry Pi so they stop gluing the lens?
Toysrfun
Mon Oct 22, 2018 2:52 am
Does original housing have M12x0.5 threads In housing or do we need to buy the base mounts and install over the top? I could care less about the factory lense or damage to it I won’t ever use it again but it looks like I happen to have a tool that should work. Still waiting for cameras to arrive however I want to install the M12x0.5 3Mp 2.8-12 varifocal 1/2.5 1:1.4 lense from aliexpress that cost $3.67. Arducam is a bit excessive for theirs preassembled.
Toysrfun
Mon Oct 22, 2018 3:00 am
These are the three different M12x0.5 lense mounts on AliExpress. I’m not sure which one is needed. Photo files were too big to upload.
1.) https://s.click.aliexpress.com/e/4QxtkDa
2.) https://s.click.aliexpress.com/e/Td1KBQC
3.) https://s.click.aliexpress.com/e/ccbfYf20
gordon77
Mon Oct 22, 2018 2:42 pm
Note you'll need one with 21mm spacing for the Pi camera, and may need to trim it a bit to avoid on board components.
mchahn
Fri Dec 07, 2018 9:31 am
The holes are 21mm apart but I wonder if you drilled (milled) them in or out to 20mm or 22mm would you run in to any traces or electronics and kill the board?
There is a lens holder designed specifically for the raspi camera. It is machined out of aluminum, has the correct hole spacing, and has a cutout for the cable to get out. It is $8.50. I'm using two of them. This is the holder for the V1 raspi. They have one for the V2 also but it has no picture. I'm sure it is as well-made as the V1.
http://www.m12lenses.com/CNC-Machined-R ... 020rpm.htm
The site, m12lenses.com, has a great assortment of lenses and lens holders. I spend too much money there. :-) I have 6 different focal length lenses to play with.
HermannSW
Fri Dec 07, 2018 5:14 pm
I bought 2pcs metal M12 lens mount for less than 2$ with free shipping:
https://www.aliexpress.com/item/2PCS-Me ... 33842.html
They have screw hole distance 22mm, but it was no problem to get screws in inclined for firm mount to camera modules:
viewtopic.php?f=43&t=45887&p=1279957#p1279957
I did decap v1 and v2 camera module, and some 8$ v1 NoIR camera modules came with M12 mount and lens already.
So if 5MP v1 camera is OK for you, one of these cameras avoids decaping and allows for new lenses easily.
One of the M12 lenses I use has 70mm focal length -- you can do cool far distance stuff with it:
viewtopic.php?f=43&t=227166
bookmark list: https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://github.com/Hermann-SW/fork-raspiraw      https://github.com/Hermann-SW/userland
https://github.com/Hermann-SW/wireless-control-Eachine-E52-drone      https://twitter.com/HermannSW
Return to “Camera board”
