EaglesEyes
raspivid - Bad video
Mon Apr 25, 2016 2:41 pm
I recently buy RPi camera module, I plug it on a RPi1 and install the last Raspbian.
I use raspvid to do video capture with the following command:
raspivid -md 0
A window open with bad video, it seem like snow
But when I use this command:
raspivid -md 6
It's works fine. I tried all mode value and only le 6 works.
Anyone has an idea to do HD video capture please ?
Ygles ;-(
CaptSunset
Re: raspivid - Bad video
Mon Apr 25, 2016 4:55 pm
Ygles, if you really need HD, you might want to return that camera board, and exchange it for the newest model. It uses the Sony IMX219 8 Megapixel sensor, photos & specs here:
https://www.pi-supply.com/product/raspb ... -8mp-1080p
6by9
Mon Apr 25, 2016 5:13 pm
Make sure the connectors are all fully home. Why mode 6 works and the others don't is a bit strange.
Do you get the low voltage coloured square up in the top right corner on your display? If so then get a better power supply.
Posting an example would be useful.
The old sensor is perfectly capable of producing HD video - returning it just because a new one comes out is taking the mickey. If it's actually faulty, then OK, but do some checking first.
EaglesEyes
Mon Apr 25, 2016 6:14 pm
Thanks all.
I don't really need HD video but the device specification explains that it can work in 1080px so I want to use it in its full capabilities.
I will share a video capture in HD mode tomorrow and an other one in mode 6 (640x480).
I supplied the RPi with a 5V 1A on the microUSB.
The connector seems to be fully at home but I will check it tomorrow (I forgot the RPi at the office....) an try with my second RPi1.
6by9
Mon Apr 25, 2016 7:43 pm
EaglesEyes wrote:I supplied the RPi with a 5V 1A on the microUSB.
The recommendation is for a 2A power supply, mainly to avoid voltage drops due to regulators being pushed beyond max on surges. 1A is running it a little tight.
EaglesEyes
Tue Apr 26, 2016 8:36 am
You can see the bad video here => https://youtu.be/XlWPmCAmDG4
You can see the good video here => https://youtu.be/w9XxD5QC87M
In the description I put the raspivid logs.
The log are fully similare (except the file name and command line) and I don't understand why, because I follow this documentation
https://www.raspberrypi.org/documentati ... /camera.md and mode 1 and mode 6 are differents (mode 1: 1920x1080 and mode 6: 640x480)
Ygles ;-(
EaglesEyes
Tue Apr 26, 2016 7:05 pm
I tried with 2A supply and the issue still present
CaptSunset
Tue Apr 26, 2016 8:48 pm
Hi again-
Just wondering about the file size in your /tmp directory; and your 'errorvid' has no imagery at all, but is 'playing'...
Can you shorten recording time, and get any other modes working?
EaglesEyes
Fri Apr 29, 2016 8:54 am
I tried to record on an external hard disk and I had the same problem.
The mode 6 and 3 works but sometimes I had an error like "No image received from sensor" (since I tried on a RPi2), I will take a new "data cable" perhaps I damaged the first one.
Return to “Camera board”
