ffoiled
Pi Cam stopped working
Wed Apr 22, 2015 7:06 pm
Model B running Raspbian
I've had a Pi Cam attached to a model B for some time, albeit one that was used intermittently. Until recently, it was working OK, but now it has stopped. I'd not made any changes to it.
I've tried updating it :
apt-get update
apt-get upgrade
and
rpi-update.
vcgencmd get_mem gpu gives me :
gpu=128M
running
I get :
mmal: mmal_vc_component_enable: failed to enable component:
ENOSPC
mmal: camera component couldn't be enabled
mmal: main: Failed to create camera component
mmal: Failed to run camera app. Please check for firmware updates
I've tried a different Pi Cam, but the result is the same (the second Pi Cam was brand new).
Any suggestions as to what to try next ?
Adrian
Frequently Ffoiled
kcx
Re: Pi Cam stopped working
Wed Apr 22, 2015 7:15 pm
I have a similar issue and just posted the same issue here (no responses yet): viewtopic.php?f=43&t=108076&e=0
ffoiled
Sat Apr 25, 2015 1:44 pm
Problem identified !
It seems that you can't run motion and vlc or raspistill at the same time, turning off motion allowed me to run vlc and raspistill (I didn't try both at the same time).
There is another thread on this :
viewtopic.php?t=44491
An observation, rather than a complaint, it would help if the error messages were a bit clearer on this.
Adrian
Frequently Ffoiled
Return to “Camera board”
