Jamesking56
ECU + Pi
Tue Apr 29, 2014 1:54 pm
Anyone have any tips on hooking up a car's ECU to a raspberry pi to pull data out of it?
I have a 1997 Nissan Micra and a Raspberry pi so far, what hardware will I need? How can I pull data out? Can I code something in Java to pull out the data that I can run on my Pi?
geoffpalmeruk
Re: ECU + Pi
Tue Apr 29, 2014 2:41 pm
what are you looking to find out from the ECU?
I would suspect some kind of ODBII port to serial then some kind of serial adapter. then you would need to port the software to run on the Pi and finally download and install the info from the manufacturer.
Would this help:
http://www.stuffaboutcode.com/2013/07/r ... -data.html
or
http://www.pistonheads.com/gassing/topic.asp?t=1216528
or
http://www.pimyride.com/
or
http://kaikretzberg.de/raspberrypi/kw12 ... pberry-pi/
Google is your friend.
fridlington
Re: ECU + Pi
Sun Dec 14, 2014 4:07 pm
Your car uses the Nissan Consult version 1 protocol
