Fireworks Launcher
Posted: Fri Aug 23, 2013 7:03 pm
by pjc123
Web site of my Raspberry Pi Fireworks Launcher.
https://www.flaminghellmet.com/launch/
Re: Fireworks Launcher
Posted: Wed Aug 28, 2013 7:51 pm
by pjc123
I added a description and some videos today.
Posted: Sat Aug 31, 2013 3:24 pm
by noob
Epi, but it looksa bit heavy
Posted: Tue Sep 03, 2013 12:32 pm
by pjc123
noob wrote:Epi, but it looksa bit heavy
The batteries are most of the weight, but since each port requires 2 Amps to launch (for a total 8 port simultaneous launch of 16 Amps), there is no way of getting away from at least one fairly hefty battery for a nights worth of launches.
Posted: Sun Sep 29, 2013 12:50 pm
by mrspaceman01
How did you make this? :?:
Posted: Mon Sep 30, 2013 12:22 am
by pjc123
mrspaceman01 wrote:How did you make this? :?:
There is a multi-page description on the web site.
Posted: Sat May 03, 2014 4:40 pm
by pjc123
Well, it is getting close to that time of year again and the itch is back. I haven't turned my pis on in almost a year, so I better start checking them out and doing some software updates. I am thinking of switching from Wheezy stable to Jessie testing, as I suspect it has stabilized a bit by now. Anyone running off of the Jessie repository? I would like the pis to have similar versions of software as my desktops that run Linux Mint Debian (LMDE), which distributes quality controlled update pack releases off of the Debian testing repository.
Posted: Mon Feb 12, 2018 9:13 pm
by pjc123
Changed website to secure SSL access.
Posted: Thu Feb 15, 2018 11:11 am
by rados-dataplicity
What do you use to ignite the fireworks ?
Posted: Thu Feb 15, 2018 12:57 pm
by pjc123
Go to the Website under Menu > Fireworks Launcher > Description > Firework Fuse Ignition Method.
Posted: Fri Feb 16, 2018 10:44 am
Ohh I see! Great project 8-)
