Th0rium
ITDB02-3.2S (3.2" display)
Tue Jun 18, 2013 2:19 pm
Hi everyone,
Has anyone used this display with the raspberry pi model B?
http://imall.iteadstudio.com/display/tf ... 19005.html
Specs:
Model IM120419005
Display Size 3.2”
Display Resolution 320 * 240
Display Interface Parallel 16 Bit
Display Controller SSD1289
Expand SD Card Socket,Touch Screen
I'm looking at adding a display to my raspberry pi but not sure if this one is compatible with the board.
any help is greatly appreciated :)
texy
Re: ITDB02-3.2S (3.2" display)
Wed Jun 19, 2013 6:40 am
I think notro's fbtft driver is compatible :
https://github.com/notro/fbtft/wiki/LCD-Modules
It doesn't mention that particular display in the supported listing, but it may 'just work' , or ask notro about it ;)
Texy
notro
Wed Jun 19, 2013 12:07 pm
I got a message a week ago from @xtramural that he got his ITDB02-3.2S working with the SPI interface circuit and the sainsmart32fb driver.
He was looking into driving it with a latched 8-bit bus, but I don't know if he has succeeded with that.
Sainsmart 3.2 post: http://www.raspberrypi.org/phpBB3/viewt ... 7&p=356810
Latched circuit: http://www.raspberrypi.org/phpBB3/viewt ... 14#p365414
xtramural
Wed Jun 19, 2013 12:44 pm
notro wrote:I got a message a week ago from @xtramural that he got his ITDB02-3.2S working with the SPI interface circuit and the sainsmart32fb driver.
I haven't had the time to experiment with the latched 8-bit bus version but can confirm that the SPI interface and the sainsmart32fb driver are a working combination with that display.
Th0rium
Thu Jun 20, 2013 11:41 am
Hi all,
Thanks for the help, I ordered my screen and should be arriving soon. I'll update the post when I get the screen working.
Thanks again
fosap
Fri Jun 28, 2013 7:27 pm
I ordered a ITDB02-3.2WD. So far it is not working yet, i hope it won't be too hard thanks to the flexfb driver.
notro
Fri Jun 28, 2013 8:12 pm
Unfortunately the HX8352-A controller is not supported by flexfb or any other FBTFT driver.
The main difference between LCD controllers are:
* Init sequence (FBTFT function: init_display())
* Registers used to set GRAM address (FBTFT function: set_addr_win())
Another issue the driver has to handle is the interface used by the display module.
FBTFT supports:
* 8-bit SPI
* 9-bit SPI
* 8-bit parallel
* 16-bit parallel (this is not tested yet)
There is also this SPI interface circuit: https://github.com/notro/fbtft/wiki/SPI ... ce-circuit
You could try and expand flexfb with a flexfb_set_addr_win_3 function that can be used with this controller.
I downloaded the latest UTFT.rar, and this is the relevant part:
UTFT/tft_drivers/hx8352a/setxy.h
case HX8352A:
	LCD_Write_COM_DATA(0x02,x1>>8);
	LCD_Write_COM_DATA(0x03,x1);
	LCD_Write_COM_DATA(0x04,x2>>8);
	LCD_Write_COM_DATA(0x05,x2);
	LCD_Write_COM_DATA(0x06,y1>>8);
	LCD_Write_COM_DATA(0x07,y1);
	LCD_Write_COM_DATA(0x08,y2>>8);
	LCD_Write_COM_DATA(0x09,y2);
	LCD_Write_COM(0x22);
	break;
Here is info on how to build FBTFT: https://github.com/notro/fbtft/wiki/Development
fosap
Fri Jun 28, 2013 9:03 pm
Ah, the flexfb developer, how convenient I'm just reading the source :)
notro wrote: Another issue the driver has to handle is the interface used by the display module.
FBTFT supports:
* 8-bit SPI
* 9-bit SPI
* 8-bit parallel
This should not be an issue, the controller does support 8/16 bit parallel interface with the usual 4 bit data control. Unless i misunderstood something that should be exactly what the other controllers use aswell.
zoelqivlie
Thu Sep 26, 2013 3:53 pm
I ordered ITDB02-3.2S too , can share experience with it...success or not...thanx ;)
tkraspilabs Indonesia | Pi 512M Rev 2 | Pi B+ | Pi 2 B | Pi Zero | Pi 3B
