Beowulfenator
Re: Build a laptop reusing a dead one.
Sat Oct 22, 2011 9:24 am
Any luck with your board, RITRedbeard?
Thunder__X
Sun Oct 23, 2011 6:46 pm
Quote from Beowulfenator on October 22, 2011, 10:24
I'm wondering the very same thing.
bmihalov
Sat Mar 31, 2012 8:52 pm
The biggest problem that I don't see discussed much involves interfacing the laptop's "internal" keyboard and touchpad to the Pi. As far as I understand, those peripherals have no built-in controller boards--instead, the controller boards are on the laptop's motherboard. Unlike the LCD interface problem, this one doesn't seem to have a simple, straightforward solution.
bobcool09
Thu Nov 29, 2012 7:05 pm
I was thinking about this also, and even though this seems like a old/dead thread, has anyone had any progress?
tufty
Thu Nov 29, 2012 7:39 pm
Lcd interfacing is doable in some circumstances using external dvi/hdmi -> lcd adapters, there's a few of those about and available relatively cheaply from ebay. Keyboard and touchpad are easily doable using either an external 'teensy' or similar, or with some driver work. I can't see it being too hard, but, as ever, the devil is in the details. Oh, and that you'll end up spending more than buying a cheap, working, and massively more powerful laptop and running linux on that.
Jonesm23
Fri Jun 07, 2013 10:07 am
I was wondering what ever happend to this thread ?
I think it would be an amazing thing to develop a add on that simply allows laptop screens to be reused if not only from the fact that reuse is a great idea and also there are so many dead laptops out there, much more than Rpi devices sold I am sure
