WastlJ
Re: Cheap 7" TFT for RPI - Chinch
Sat Apr 07, 2012 1:25 pm
Hey
found this one:
http://cgi.ebay.de/ws/eBayISAP.....853wt_1348
What do you think about it?
W.
john_wage
Sat Apr 07, 2012 2:22 pm
connectors look a bit iffy, would probably work with some tinkering
but 480 x 234 is a very low res display also unless you install it in car you'll need to come up with your own power supply, I assume standard 12V as in car batteries.
brian_reiter
Re: Cheap 7
Thu May 24, 2012 11:32 am
The one I received (looks very similar) is easily powered from a 12Volt supply (used a one I had for LED strip lights). Haven't tried on the Pi yet but works fine with the DuinoMite. In the UK it costs £25 including postage from China.
