Case for PiFace Digital
Posted: Fri Feb 22, 2013 1:33 pm
by killor
Today I received my Piface PCB and I am making a new box for this new union.
It is a first test, not the final, because I did have the CASE before the new PCB physically and I must set some measures of the windows to make it look better
and any piece cause the buttons to access from outside the box. :mrgreen:
Piface box
Pi face box
Piface digital BOX
The overall dimensions are
40mm high x 68mm wide x 98mm long
These days, I finish the details and I will have ready for sale on eBay and Amazon, if anyone is interested in them. ;)
Re: Pi face BOX
Posted: Sat Feb 23, 2013 2:03 pm
by killor
Last night, I was doing a case in of birch plywood to accommodate the RPI and PiFACE.
RPIFace box
Raspberry pi face box
I made a plywood buttons to access the keypad inside without opening the top. :mrgreen:
Raspberry PI face case
Re: Case for PiFace Digital
Posted: Wed Mar 20, 2013 6:25 pm
by waterman480
Ordered my acrylic case on EBay yesterday - can't wait
Posted: Wed Mar 20, 2013 10:53 pm
by dan3008
love the plywood buttons :)
Re: Case for PiFace Digital and Raspberry Pi
Posted: Thu Mar 28, 2013 7:46 pm
by killor
This is my last case for Raspberry and Piface made ​​of clear acrylic.
Raspberry PiFace acrylic case
I added a piece of acrylic to transmit light from the LEDs to the top.
Now also accept Bitcoins (BTC) to sell. :lol: on Bitmit web site.
Posted: Wed Jun 12, 2013 8:44 am
by beruic
It's beautifull in wood.
Posted: Fri Jun 14, 2013 5:38 pm
by killor
beruic wrote:It's beautifull in wood.
And more resistant to shocks.
Less electrostatic charge.
Since the grain is always different in some way, each case is unique.
100% biodegradables.
Posted: Mon Jul 15, 2013 6:14 pm
by killor
I made a new piece for the bottom of the case.
Now the cases is adapted for VESA Mounting Interface Standard (MIS) or colloquially as VESA mount.
VESA MIS-D 100mm x 100mm or 75mm x 75mm
Now we just put the M4 screws and voila! ;)
Piface enclosure with VESA botton
enclosure Raspberry pi .Adapter for PiFace board and Vesa mount
Raspberry Piface plywood case with Vesa mount
Soon will be available on AMAZON. B00BM4YP2C
Re: Case for PiFace Digital and Digital 2 boards..
Posted: Thu Oct 01, 2015 7:10 pm
by killor
Hi :!:
I designed a new enclosure model adapted to the new versions of boards
Raspberry Pi 2 and PiFace Digital 2.
Birch ply is made from laminations of birch veneer. It is light but strong, among the strongest and most dimensionally-stable plywoods. :mrgreen:
Made of birch plywood this case keeps the Pi secure, has a hinged top for connector access, and even has little feet cut into the sides so that it stands up above your desk.
You can use all of the connectors on the edges of the Pi: HDMI, Audio/Video, microSD slot, micro USB power, Ethernet and the 4 USB ports.
There's also a cut out to allow a 40-pin IDC cable to the GPIO breakout pins on the Pi and pass it though the case and 2 rectangular openings for PiFACE board ports.
For more advanced hacking, the enclosure is designed so that you can lift or remove the top piece and plug any sort of cables you wish into the breakouts in the middle. :ugeek:
The case is airy enough that no additional vents or cooling is required - we tested the enclosed Pi over a 24 hour period at full load with no significant increase in temperature.
Sales on ETSY https://goo.gl/MEFZTO and eBay sites... ;)
