marXmit
Re: R-pi + main components 3D-model SolidWorks and IGES
Sun Jan 22, 2012 4:20 pm
For casing designers-to-be:
Based on Gert's technical drawing and photo's, I created a SolidWorks2010 assembly with model-B componets which I found on several electronics component sites. I tried to choose them as accurately as possible, not sure however which will be exactly on the "real thing". However, measurements may easlyly be changed in the SW model.
SW-assembly, parts and IGES in:
http://dl.dropbox.com/u/364195.....SW2010.zip
Use & change them as you like; can't wait to see well-designed casings for different target-groups, applicatios and environments!
If needed, I'll be glad to "save as" different formats.
Happy CADing!
HansH
Sun Jan 22, 2012 4:58 pm
very nice, thx..
What I can see the pcb board is actually 56mm width instead of 53.98mm... correct ?
marXmit
Sun Jan 22, 2012 6:28 pm
Yes, that's the dimension i've got from Gert's drawing
effbiai
Mon Jan 23, 2012 3:45 pm
Happy CADing!
are you able to save this as 'skp' (Google SketchUp)?
marXmit
Tue Jan 24, 2012 9:03 pm
effbiai said:
marXmit said:
If needed, I"ll be glad to "save as" different formats.
Happy CADing!
are you able to save this as "skp" (Google SketchUp)?
sorry.. no way to save as Sketchup; there are converters available but none free-of-charge i'm afraid. Maybe via Blender?
Gert van Loo
Tue Jan 24, 2012 9:28 pm
I am sure the 56 is correct. I read that somebody also checked my dimensions against the pictures and found the 53.98 implausible.
HansH
Wed Jan 25, 2012 11:00 am
yep its 56mm, I also checked it against the pictures of the pcb board, rescaled them and found 560 pixels against 850 pixels…
Montekuri
Wed Jan 25, 2012 12:23 pm
marXmit - you could save as (export) dxf file.
Jaseman
Wed Jan 25, 2012 1:22 pm
I can see a modding club spin off.
How long before Raspberry Pi goes 'Neon'?
tanso
Wed Jan 25, 2012 7:25 pm
dxf is 2D.
marXmit created a 3D CAD file. Thank you, marXmit! I opened it in Solid Works.
botbry
Fri Feb 24, 2012 12:37 pm
dxf is 2D.
Creating a DXF is easy in SolidWorks. Make a new drawing (DRW/SLDDRW) file with all the views that you need, then simply save the drawing file as a DXF. DONE.
Stew2000
Sat Mar 03, 2012 12:35 pm
If anyone is interested (and because I want to model a case), I converted the model to .obj and gave the board a quick texture.
Download: http://cl.ly/1e252d1Z0y451z0b0.....10_obj.zip
Joules
Fri Mar 09, 2012 12:13 pm
Thanks Stew,
went straight into Rhino (Mac beta version) and working with it now.
C4B7
Sat Mar 10, 2012 4:21 am
Marxmit,
Thanks! This is awesome!
We should start pointing everyone to the wiki so we can all share ideas and collaborate.
http://elinux.org/RPi_Cases
Let's start an aftermarket for raspberry pi.
E
Sun Apr 01, 2012 1:58 pm
Thanks both marXmit and Stew
jehan60188
Wed Jul 18, 2012 3:13 am
the file is gone, can someone please reup the original (solidworks) file?
thanks!
FarmerBrown87
Thu Jul 19, 2012 4:12 pm
Raspberry Pi newbie here,
I'm getting CAD training at work and have been told to practice on a 'non-work' project to hone my training, a raspberry pi case was an obivous choice as mine only arrived the other day.
Does anyone have a copy of this CAD file about? I'd like to use it to reference off.
Thanks,
FB
jehan60188
Thu Jul 26, 2012 9:56 pm
came across this earlier today
http://solidworksbootcamp.com/raspberry ... enclosure/
the zip file has a case, but also has a model of the R-pi itself
unclouded
Fri Jun 27, 2014 8:33 am
If anyone wants an OpenSCAD model to start from then I've posted one at this link:
