Annihilation989
Raspberry pi rfid door lock
Sun Sep 08, 2019 7:29 pm
Hello, I was wondering if anyone could help me,
I have been following this guide (https://github.com/plenkyman/RFID_RC522 ... lation.txt) to make an rfid door lock, however, when I try to set up the cards, I get an error, might it be that i'm running this on buster, but it says it is run on jessie.
I have tried contacting the creator, but unfortunately, he hasn't been online since 2017.
Any help would be greatly appreciated,
Tim
The error:
File "/usr/local/lib/python3.7/dist-packages/pymysql/connections.py", line 571, in connect
sock.connect(self.unix_socket)
FileNotFoundError: [Errno 2] No such file or directory
During handling of the above exception, another exception occurred:
File "SetupCards.py", line 26, in <module>
connection = pymysql.connect(host=tdp.rpi_ip,unix_socket='/var/run/mysqld/mysqld.sock', user=tdp.dbUs, passwd=tdp.dbPW, db=tdp.dbNa)
File "/usr/local/lib/python3.7/dist-packages/pymysql/__init__.py", line 94, in Connect
return Connection(*args, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/pymysql/connections.py", line 325, in __init__
self.connect()
File "/usr/local/lib/python3.7/dist-packages/pymysql/connections.py", line 630, in connect
raise exc
pymysql.err.OperationalError: (2003, "Can't connect to MySQL server on 'localhost' ([Errno 2] No such file or directory)")
topguy
Re: Raspberry pi rfid door lock
Mon Sep 09, 2019 10:36 am
The script expect a running MySQL server on "localhost" that connection is what fails.
There is a big chance that the "thedoor_full_install_v9.sh" doesnt quite work on Buster because packages has changed names etc..
Annihilation989
Mon Sep 09, 2019 5:55 pm
Thanks for the reply, I will try jessie
Annihilation989
Thu Sep 12, 2019 9:54 pm
I have tried jessie, but the reader wasn't running, I googled around and found out the reader doesn't work with the latest version of jessie, could anyone confirm this?
Many thanks,
Tim
topguy
Fri Sep 13, 2019 8:49 am
Using Jessie which is very old, could be difficult in general, a better solution is to learn how the solution is supposed to work and learn set it up manually.
Annihilation989
Sun Oct 13, 2019 7:14 am
Everything works, except the script for setup cards fails because I don't know the directory for the reader
topguy
Sun Oct 13, 2019 10:51 am
You have to give more information about the script and what directory you are talking about if you want help.
Annihilation989
Mon Oct 14, 2019 7:27 am
The door script runs and checks for any cards on the reader, if the card has a an id that's stored in the database, then the script checks what level of clearance has been assigned to it and if it's authorized to access the room at that time and date, if not a red led turns on and the card is logged to the database of rejected cards, the script then takes a photo of the person, if a card is accepted, a relay will be switched and the electromagnet will turn off for 3 seconds.
The program I'm trying to run is setup cards, which allows you to set cards and the access level for them, however, when I run the program, it skips the reading cards bit and just exits the program. I thought it might have something to do with the directory for the reader being wrong, because there's a program you can run which will allow you to change gpio pins for leds and directories for different things, I looked in the default directory for the reader, but saw nothing that resembled a reader.
Any help would be appreciated
topguy
Mon Oct 14, 2019 11:06 am
And what is this directory called ?
So far we don't even know how the reader is connected to the Pi or which RC522 module you have bought.
Its very hard to follow that project you linked to, to be honest.
The code try to start another program:
reader = RFIDReaderWrapper("sudo nohup "+tdc.p2r+"/rc522_reader -d 2>&1")
I dont know where this "rc522_reader" program is supposed to come from, but most likely its from here: https://github.com/plenkyman/rpi-rc522/ ... ster/rc522
Annihilation989
Mon Oct 14, 2019 4:53 pm
Thanks for your reply,
The reader is connected over spi and the default directory for the reader is home, this is the reader I bought:
https://www.amazon.co.uk/dp/B076HTH56Q/ ... PDbMK0DCTX
B.Goode
Mon Oct 14, 2019 5:07 pm
Referring back to your original query -
The substantive error appears to be
Why is it unable to connect?
Can you confirm that you are running a MySQL-compatible database server on your Raspbian Buster Operating System to which your code can make a connection?
