anh2ah
How to internal website send command to terminal raspbian
Thu Jun 06, 2019 2:04 am
I have created a website to control the car using Rasp pi 3+.
Also created a python program to control it, it has a name: AutorunCar.py
When I run: sudo python AutorunCar.py in the terminal, it's working normally
but I don't know how to call that program on my website with HTML code
Please help me solve this problem, thank in advance :)
scotty101
Re: How to internal website send command to terminal raspbian
Thu Jun 06, 2019 10:08 am
Perhaps you could share your code?
As an example, I created something a while back to send IR commands via a python script from a web page. This allowed me to control my TV from a web browser on my phone.
https://github.com/scotty3785/pi_tv_remote
It uses python-flask, a framework for creating dynamic web content with python. Pressing a button on the webpage, sends a command back to the python code running on the pi to send the different IR signals.
Something like this could be modified quite easily to control a car/robot.
anh2ah
Fri Jun 07, 2019 10:30 am
Thanks, Scotty!
Your post is working well,
but when I run .py file on startup it doesn't work (sudo nano /etc/rc.local)
Do you have any idea to solve it,
Thanks and I wish you have a good day!
omegaman477
Sat Jun 08, 2019 5:17 pm
In Python, there are many ways to execute external programs. The easiest one is to import the os package. It provides the popen(), system(), startfile() methods.
But it is dependant on your local O/S.
os.popen() should solve your needs.
..the only thing worse than a stupid question is a question not asked.
klricks
Sat Jun 08, 2019 7:05 pm
Thanks, Scotty!
If your script requires Desktop (GUI) then you can't start it with rc.local.
Use autostart instead:
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
anh2ah
Tue Jun 11, 2019 12:50 am
Thanks klricks!
Now, my program working well
Thanks for your help and I wish you have a good day!
