Jagohu
APCUPSD with multiple UPS on Stretch
Sat May 18, 2019 11:57 pm
I've been trying to make this work, but I just can't figure it out, so I'd like to ask for some help.
I have two APC backups (1400, 950) connected to my RPI3 via USB.
I have completed the steps of the manual: https://wiki.debian.org/apcupsd#Configu ... Devices.29
udev is working fine, devices are mapped properly.
/etc/default/apcupsd isconfigured=yes
Where I got stuck is that if I don't have a /etc/apcupsd/apcupsd.conf file present, "only" as suggested the /etc/apcupsd/apcupsd.network.conf and /etc/apcupsd/apcupsd.heating.conf files, the service won't start.
I can manually start it with ie. apcupsd -f /etc/apcupsd/apcupsd.heating.conf
In that case if I try service apcupsd report, it works fine(get all the data from both UPSes), but if I try service apcupsd status it says it's not running - and it's due to the lacking /etc/apcupsd/apcupsd.conf file. Additionally every document I came across with says that I shouldn't have a /etc/apcupsd/apcupsd.conf file if I have multiple UPSes.
This is my /etc/init.d/apcupsd file (I have tried the one from the forum as well, but that didn't work well for me from this post: https://www.raspberrypi.org/forums/view ... hp?t=85154
### BEGIN INIT INFO
# Provides: apcupsd
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Should-Start: $local_fs
# Should-Stop: $local_fs
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Controls the apcupsd daemon for multiple UPS devices
# Description: apcupsd provides UPS power management for APC products.
### END INIT INFO
echo "Start reading /etc/init.d/apcupsd"
# Installation customizable fields.
#USELOCK=false
SUMMARYFIELDS='UPSNAME|MODEL|SERIALNO|STATUS|LINEV|LOADPCT|BCHARGE|TIMELEFT|OUTPUTV|ITEMP|ALARMDEL|BATTV|LINEFREQ|LASTXFER|NUMXFERS|TONBATT|CUMONBATT|BATTDATE|HUMIDITY|AMBTEMP'
SMSFIELDS='UPSNAME|STATUS|BCHARGE|TIMELEFT|LASTXFER|TONBATT'
NAME=apcupsd
DESC="This script controls the apcupsd daemon for multiple UPS devices."
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DAEMON=/sbin/apcupsd
APCTEST=/sbin/apctest
CONFIG=/etc/default/apcupsd
CONFDIR=/etc/apcupsd
# RUNDIR=/var/run
RUNDIR=/run
. $CONFIG
. /lib/lsb/init-functions
test -x $DAEMON || exit 5
test -x $APCTEST || exit 5
test -x $apcaccess || exit 5
test -e $CONFIG || exit 5
test -d $CONFDIR || exit 5
if [ "$ISCONFIGURED" != "yes" ]; then
        log_failure_msg "Check your configuration ISCONFIGURED in $CONFIG"
        exit 6  # program is not configured
fi
ls $CONFDIR/apcupsd*.conf > /dev/null 2>&1
statusCode=$?
if [ $statusCode -gt 0 ]; then
        log_failure_msg "No apcupsd configuration files found in $CONFDIR"
        exit 6
fi
case "$1" in
start|stop|restart|force-reload|status|report|summary|sms|test)
        # Each one of these commands are run for all apcupsd configuration files
        # unless a UPSNAME is specified, which will run the command only for
        # that UPS.
        # Note: If a daemon is started, and its conf file is deleted or
        # otherwise can't be found by this script, then this script wont be able
        # to control that daemon.
        if [ "$1" = "start" ]; then
                rm -f $CONFDIR/powerfail
                rm -f /etc/nologin
        fi
        count=0  # Used for white space control in report/summary/sms commands.
        counter=0
        if [ "$1" = "report" ] || [ "$1" = "summary" ] || [ "$1" = "sms" ]; then
                # Count the number of conf files found.
                for conf in $CONFDIR/apcupsd*.conf ; do
                        count=`expr $count + 1`
                done
        fi
        foundUPS=false  # Used only when a UPSNAME is specified.
        errorOccured=false
        statusCode=0
        errorCode=0
        # Loop through the $CONFDIR and find any conf file matching the pattern below.
                inst=`basename $conf`
                UPSNAME=$(cat $CONFDIR/$inst | grep "^[^#]" | grep "UPSNAME" | awk '{printf $2}')
                # Check that UPSNAME exists in configuration file.
                if [ -z "$UPSNAME" ]; then
                        log_failure_msg "UPSNAME is not configured in $inst (skipping)"
                        errorOccured=true
                # Continue if either no UPS was specified or the specified UPS was found.
                elif [ -z "$2" ] || ( [ -n "$2" ] && [ "$UPSNAME" = "$2" ] ); then
                        foundUPS=true
                        case "$1" in
                                start)
                                        # Show the daemon's status if it's running.
                                        OUTPUT=$($0 status "$UPSNAME")
                                        returnCode=$?
                                        if [ $returnCode -gt 0 ]; then
                                                log_daemon_msg "Starting UPS monitor (for $UPSNAME UPS)" "apcupsd"
                                        else
                                                echo "$OUTPUT"
                                        fi
                                        start-stop-daemon --start --quiet --oknodo --pidfile /run/$inst.pid --exec $DAEMON -- -f $conf -P /run/$inst.pid
                                        statusCode=$?
                                        # If the daemon wasn't running, show start result.
                                        # (We still try starting if it wasn't running, just
                                        # in case, but we do it quietly.)
                                        if [ $returnCode -ne 0 ]; then
                                                log_end_msg $statusCode
                                        fi
                                stop)
                                        # Show the daemon's status if it's not running.
                                        returnCode=$?
                                                echo "$OUTPUT"
                                        else
                                                log_daemon_msg "Stopping UPS monitor (for $UPSNAME UPS)" "apcupsd"
                                        fi
                                        start-stop-daemon --stop --quiet --oknodo --pidfile /run/$inst.pid
                                        statusCode=$?
                                        # If the daemon was running, show stop result.
                                        # (We still try stopping if it was running, just in
                                        # case, but we do it quietly.)
                                        if [ $returnCode = 0 ]; then
                                        fi
                                restart|force-reload)
                                        $0 stop "$UPSNAME"
                                        #echo -n "Waiting for just a moment..."
                                        sleep 1
                                        #echo "done."
                                        $0 start "$UPSNAME"
                                status)
                                        status_of_proc -p /run/$inst.pid $DAEMON "UPS monitor (for $UPSNAME UPS)" && statusCode=0 || statusCode=$?
                                report|summary|sms)
                                        # Report shows full details; summary shows just
                                        # pertinent info; sms shows a very short one liner.
                                        # This code parses the conf file and find the NISPORT
                                        # and NISIP, then display the status of UPS using
                                        # "apcaccess status NISPORT:NISIP" so each UPS needs to
                                        # be configured to have NIS running on a different port.
                                        counter=`expr $counter + 1`
                                        nisport=$(cat $CONFDIR/$inst | grep "^[^#]" | grep "NISPORT" | awk '{printf $2}')
                                        nisip=$(cat $CONFDIR/$inst | grep "^[^#]" | grep "NISIP" | awk '{printf $2}')
                                        if [ "$1" = "summary" ]; then
                                                # Shows only pertinent info.
                                                apcaccess status $nisip:$nisport | grep -E $SUMMARYFIELDS
                                        elif [ "$1" = "sms" ]; then
                                                # Produces a short, condensed one line string.
                                                # Note: The output doesn't contain a trailing newline.
                                                apcaccess status $nisip:$nisport | grep -E $SMSFIELDS | sed 's/\(^[A-Z]*\)\( *\)\(:\)/\1\3/;s/ *$//;s/ Percent/%/i;s/Minutes/min/i;s/seconds/sec/i;s/UPSNAME:/UPS/;/^STATUS: /s/$/\;/;s/STATUS: //' | tr '\n' ' ' | sed 's/ *$//'
                                        else
                                                # Shows all details.
                                                echo "APCUPSD  : $nisip:$nisport"
                                                echo "CONFFILE : $inst"
                                        fi
                                        if [ -z "$2" ] && [ $count -gt 1 ] && [ $counter -lt $count ]; then
                                                # Only show newline white space if there's more than one
                                                # UPS and it's not the last UPS being shown.
                                                echo
                                        fi
                                test)
                                        # Runs apctest for a specific UPS. Automatically stops
                                        # apcupsd if it's running and restarts it when finished.
                                        if [ -z "$2" ]; then
                                                log_failure_msg "A specific UPSNAME is required but not provided."
                                                exit 2  # invalid or excess argument(s)
                                        else
                                                # Check if apcupsd is running for this UPS.
                                                $0 status "$UPSNAME" > /dev/null 2>&1
                                                returnCode=$?
                                                        $0 stop "$2"
                                                        sleep 3
                                                        echo "done."
                                                fi
                                                $APCTEST -f $conf
												# -> apctest -f /etc/apcupsd/apcupsd-network.conf
                                                # Restart apcupsd if it was running.
                                                        $0 start "$2"
                                                fi
                                        fi
                        esac
                        # Record that a non fatal error occurred somewhere.
                                errorOccured=true
                                errorCode=$statusCode
                                # errorCode may get overridden but only with another error
                                # code, so at the very least the last error code will be
                                # returned (see below).
                        fi
                fi
        done
        # Display an error if a UPS was specified but not found.
        if [ -n "$2" ] && [ "$foundUPS" = "false" ]; then
                log_failure_msg "UPSNAME '$2' not found in any apcupsd configuration file."
                exit 1  # generic or unspecified error
        # If an error code was returned somewhere, exit with it.
        elif [ $errorCode -gt 0 ]; then
                exit $errorCode
        # If any other error occurred, exit with a generic error code.
        elif [ "$errorOccured" = "true" ]; then
                exit 1
        fi
        exit 0  # Everything seems to have finished successfuly!
reload|try-restart)
        log_failure_msg "Actions reload and try-restart are not implemented."
        exit 3  # unimplemented feature
        N=/etc/init.d/$NAME
        echo $DESC
        echo "Each $CONFDIR/apcupsd*.conf file found will run a separate apcupsd process."
        echo
        echo "Usage: $N {start|stop|restart|status} [UPSNAME]"
        echo "Usage: $N {report|summary|sms} [UPSNAME]"
        echo "Usage: $N test UPSNAME"
        echo
        echo "The start, stop, restart, and status commands control apcupsd processes."
        echo
        echo "The report, summary, and sms commands runs 'apcaccess status'. A report"
        echo "shows full apcaccess status details, summary shows just pertinent info,"
        echo "and sms shows a very short one liner."
        echo
        echo "The test command runs 'apctest' on a specific UPS."
        echo
        echo "The UPSNAME must be set for each UPS in each configuration file."
esac
[code]## apcupsd.conf v1.1 ##
# apcupsd.heating.conf
# General Configuration Directives
UPSNAME heating
UPSTYPE usb
UPSCABLE usb
DEVICE /dev/usb/ups-heating
# empty "DEVICE" results in addressing the "first" - heating UPS only.
# DEVICE /dev/usb/hid/hiddev1 results in unable to start
POLLTIME 60
LOCKFILE /var/lock3
# Configuration Directives Used by the Network Information Server
NETSERVER on
NISIP 127.0.0.1
NISPORT 3551
EVENTSFILE /var/log/apcupsd.heating.events
#EVENTSFILEMAX 10
# Configuration Directives used during Power Failures
BATTERYLEVEL 5
MINUTES 3
TIMEOUT 0
ANNOY 300
ANNOYDELAY 60
NOLOGON disable
#NOLOGONDIR /etc
KILLDELAY 30
SCRIPTDIR /etc/apcupsd/scripts.heating
PWRFAILDIR /etc/apcupsd/scripts.heating
# Configuration Directives used to Control System Logging
STATTIME 0
#STATFILE /var/log/apcupsd.heating.status
DATATIME 0
FACILITY DAEMON
# Configuration Directives for Sharing a UPS
UPSCLASS standalone
UPSMODE disable
# apcupsd.network.conf
UPSNAME network
UPSTYPE usb
UPSCABLE usb
DEVICE /dev/usb/ups-network
# DEVICE /dev/usb/hid/hiddev0 results in unable to start
POLLTIME 60
LOCKFILE /var/lock2
NETSERVER on
NISIP 127.0.0.1
NISPORT 3552
EVENTSFILE /var/log/apcupsd.network.events
#EVENTSFILEMAX 10
BATTERYLEVEL 5
MINUTES 3
TIMEOUT 0
ANNOY 300
ANNOYDELAY 0
NOLOGON disable
#NOLOGONDIR /etc
KILLDELAY 60
SCRIPTDIR /etc/apcupsd/scripts.network
PWRFAILDIR /etc/apcupsd/scripts.network
STATTIME 0
#STATFILE /var/log/apcupsd.network.status
DATATIME 0
FACILITY DAEMON
UPSCLASS standalone
UPSMODE disable
Thank you for any help in advance!code
omegaman477
Re: APCUPSD with multiple UPS on Stretch
Sun May 19, 2019 4:10 am
Check your system log files, what is the error(s) apcupsd is logging when it fails.
Feels like a config syntax error.
Invoke apcupsd with -d 9, to enable detailed logging.
..the only thing worse than a stupid question is a question not asked.
Jagohu
Mon Jun 03, 2019 10:25 am
Hi!
Thank you for the reply! Unfortunately it took me a while to try your suggestion.
sudo apcupsd -d 9
apcupsd FATAL ERROR in apcconfig.c at line 614
Error opening configuration file (/etc/apcupsd/apcupsd.conf): No such file or directory
I get this error message. Do you maybe have any other suggestions?
It is right in a way, because both .conf files are like apcupsd.heating.conf and apcupsd.network.conf - but I still don't get it why can't it find those two...
Jagohu
Thu Oct 17, 2019 3:41 pm
For those eventually struggling with this problem, monitoring 2 or more UPS through APCUPSD and stumble through this topic:
I've been struggling with this only to find a solution now after a lot of trial and error. I use a Raspberry Pi 3 with 2 APC UPS on its USB ports.
The key point is basically to follow the guide: https://wiki.debian.org/apcupsd#Configu ... Devices.29
1. If you have done the first steps of USB redirect, test it:
ls -l /dev/usb
If it shows something like this you're good:
crw------- 1 root root 180, 96 Oct 17 13:42 hiddev0
crw------- 1 root root 180, 97 Oct 17 13:42 hiddev1
lrwxrwxrwx 1 root root 7 Oct 17 13:42 ups-heating -> hiddev0
lrwxrwxrwx 1 root root 7 Oct 17 13:42 ups-network -> hiddev1
2. Once you're done with all the steps including this one in the manual: "Mark apcupsd as configured" and it won't run properly when you type:
service apcupsd start
You need to start the instances manually (there might be a way to do it automatically, but I haven't looked into it yet, I'm just happy it works):
apcupsd -f /etc/apcupsd/apcupsd-network.conf
apcupsd -f /etc/apcupsd/apcupsd-heating.conf
You might not see any result of this, but you can check if they work:
service apcupsd report network
or
service apcupsd report heating
This should give you the output:
APCUPSD : 127.0.0.1:3551
CONFFILE : apcupsd-network.conf
APC : 001,037,0940
DATE : 2019-10-17 17:36:46 +0200
HOSTNAME : raspberrypi3kruipkelder
VERSION : 3.14.14 (31 May 2016) debian
UPSNAME : network
CABLE : USB Cable
DRIVER : USB UPS Driver
UPSMODE : Stand Alone
STARTTIME: 2019-10-17 13:55:09 +0200
MODEL : Back-UPS XS 950U
STATUS : ONLINE...
Although it will still show as a non-running service, it'll still be running in the background. I hope this helps you!
