tpyo kingg
Multiple DS18B20 data lines on one GPIO pin?
Wed May 15, 2019 3:38 am
Can I use multiple DS18B20 temperature sensors on the same pins? Specifically, can the data wires (DQ) for several sensors all be run to a single GPIO pin and share the pull-up resistor? The specifications mention a unique 64-bit address so that would imply it is possible to share the same one-wire bus. I suppose it makes no difference about shared GND and Vdd.
omegaman477
Re: Multiple DS18B20 data lines on one GPIO pin?
Wed May 15, 2019 3:49 am
Yes.
The DS18B20 is an I2C bus device, or 1-Wire. Yes, each DS18B20 has an internal unique address. Follow the datasheet examples for topology and pullup resistor.
The default I2C libraries for Raspbian support multiple I2C devices on the one bus/pin. The application suite I2C-tools provides valuable debugging and diagnostic tools. Python (as with most languages for Raspbian) has libraries for full I2C device specific support
..the only thing worse than a stupid question is a question not asked.
tpyo kingg
Wed May 15, 2019 3:52 am
Thanks. That will simplify things.
Wed May 15, 2019 4:11 am
Yes.
1-Wire and I2C are entirely different buses.
The DS18B20 is a 1-wire device. You are correct that it is possible to run several of them on one bus. It is also possible to run multiple buses on the Pi.
dmagill4
Wed May 15, 2019 12:45 pm
Just remember the DS18b20's are each given a unique somewhat random serial number during production. once you have 3 or 4 all hooked up there will be a folder for each one (by name -- name = serial number) under the W1_master folder on the system drive. IIRC the system will find them each time based on the serial number in alphabetical order -- so once you know which one is which, they should stay the same (until you introduce a new sensor)
tpyo kingg
Wed May 15, 2019 6:58 pm
Ok. Thanks. The order is not an issue as long as the folders don't change names. For example, I have these two on one machine now:
/sys/bus/w1/devices/28-00000a2a3d2e/w1_slave
/sys/bus/w1/devices/28-00000916ba9c/w1_slave
Can I presume that if I add a third, those two will remain as they are?
Wed May 15, 2019 7:46 pm
Yes. Those names are based on the serial numbers of the sensors and those will never change.
dmagill4
Thu May 16, 2019 11:05 am
Your Third may pop into any position (based on its serial #) - So if you are using code that finds them for you and returns something like Device[0] = 28-00000a2a3d2e and your new device has a lower serial number it will become device[0] and this one will be device[1]
it's just a matter of how you are calling the devices (spelled out like above) or having a subroutine find them and build an array.
As stated above folder 28-00000a2a3d2e/W1-slave will always equal that physical sensor
