Probe Module for Ds18b20 -- Alternative?
Posted: Tue May 07, 2019 12:31 am
by iwiber
I'm not very electronic savvy.. is there something else than this that I could use since it's super hard to find? Like welding resistances or something else?
Your help would be much appreciated.
Re: Probe Module for Ds18b20 -- Alternative?
Posted: Tue May 07, 2019 8:57 am
by pcmanbob
I assume you are asking about connecting a DS18B20 to your pi gpio.
all you need is a 4.7K resistor and the DS18B20 connected like this to the gpio.
no probe module is required or needed.
The module you posted a picture of is just a way of connecting a DS18B20 via the screw terminals with the 4.7K resistor already mounted on the PCB, providing a easily connectable output for the wiring to the pi,
if you particularly wanted such an interface PCB you could build one using some strip board , a screw terminal block , a 4.7K resistor and some right angle PCB connector pins.
Posted: Tue May 07, 2019 9:27 am
by iwiber
Awesome thanks!
Posted: Tue May 14, 2019 7:51 am
by omegaman477
Adafruit have an encapsulated, waterproof DS18B20. https://www.adafruit.com/product/381
Posted: Tue May 14, 2019 10:55 am
by iwiber
That's the one I have
